Water Fall Sound
Water Fall Sound
I recently had to drain and refill all of the coolant. Now I get the water fall sound only when floored and at 4k plus RPM?
I probably would have never noticed it but I pulled out in front of some traffic and realized I wasn't in my X5 Had to floor the old dog and wind out some gears. I don't hear the sound any other time. I've bleed the system again to ensure there is no air in it. What else could it be?
If is is air. At WOT, it could also be exhaust gas (head gaskets). There is a chemical test that will change color for that. As for bleeding, many release and elevate the coolant bottle as part of the bleed process. Others have fabbed a new "T" with a drain tube, see pix. There are always more bubbles after the first 2 or 3.
Family member of yours Buzz?
nopistons94
07-15-2005 12:13 AM
