Water Fall Sound
Old Jul 27, 2013 | 09:44 AM
caymandrew's Avatar
Default Water Fall Sound
I recently had to drain and refill all of the coolant. Now I get the water fall sound only when floored and at 4k plus RPM?
I probably would have never noticed it but I pulled out in front of some traffic and realized I wasn't in my X5 Had to floor the old dog and wind out some gears. I don't hear the sound any other time. I've bleed the system again to ensure there is no air in it. What else could it be?
Old Jul 27, 2013 | 09:50 AM
dgi 07's Avatar
Sorry to say, you may think there is no air, but there is.......
Old Jul 27, 2013 | 09:53 AM
caymandrew's Avatar
That's good news. I like simple fixes
Old Jul 27, 2013 | 10:48 AM
Madlands's Avatar
I always pop my hood and check everyday for about a week after replacing coolant. That's after spending what seems like forever trying to bleed the lines. Sometimes it takes a little driving to work out some air bubbles it seems.
Old Jul 27, 2013 | 12:33 PM
If is is air. At WOT, it could also be exhaust gas (head gaskets). There is a chemical test that will change color for that. As for bleeding, many release and elevate the coolant bottle as part of the bleed process. Others have fabbed a new "T" with a drain tube, see pix. There are always more bubbles after the first 2 or 3.
Old Jul 27, 2013 | 01:56 PM
dgi 07's Avatar
That is shade-tree as hell. Genius, but shade-tree.
Family member of yours Buzz?
Old Jul 27, 2013 | 03:19 PM
caymandrew's Avatar
The head gaskets were done about 10k miles ago, and I've drained and refilled the coolant three times in the last few weeks. This is the first time I've heard the waterfall sound. I'm sure it's just air. Given the frequency in which I seem to be taking off the timing cover lately, I should take the time to put the T drain tube in!
Old Jul 27, 2013 | 11:43 PM
dr. mordo's Avatar
Several months ago I drained the system and had the waterfall sound no matter how much bleeding I did.
Recently I had to refill it again, and this time while bleeding I was tapping on the T and wiggling it around. No waterfall now.
Old Jul 28, 2013 | 07:29 AM
The Home Depot engineered one was original post of member primussucks.
Cosmic88
Oct 26, 2010 12:31 PM
Frank4
Mar 15, 2009 07:42 PM
jacksyachts
May 2, 2007 02:02 PM
nopistons94
Jul 15, 2005 12:13 AM
