Water Ingress Passenger Footwell
Old Jun 27, 2021 | 05:09 AM
RizzleKicks's Avatar
Default Water Ingress Passenger Footwell
Hi All ,
D2 - 2004
Quick update finally got the windscreen engineer back out and he’s now refitted the bottom outer windscreen finisher seal and will be putting a bit of silicon behind it also do that it sits tight up again the screen.
Something i brought to his attention was when the scuttle panel is removed and the air intake is visible the water would just come of the windscreen and straight into the air intake box and out behind the glove box.
See image below
Air Intake is it supposed to have a cover ?
My question is does this filter have a cover to prevent this from happening ?
What I did to prevent water coming in was put a piece or Perspex which runs the length of the Air Intake and an inch longer with side to create a hood so water now runs over the Perspex and into the drain holes on the inner wings 😉
🤞 has a few heavy showers and all is 🦴 dry.
Cheers
RizzleKicks
Old Jun 27, 2021 | 08:25 AM
dswilly's Avatar
Mine did not have a cover and I don't think they do. When I had my cowl off it looks like the fresh air intake should create a dam for the water to run off the sides if everything is working correctly. The lip sticks out about .75" or so from the firewall in upward direction. In you pictures it doesn't look like it stick out that far. It also looks like the sealant someone gooped on it might actually create a ramp that water would flow over and into the intake. Path of least resistance, which water likes.
Old Jun 27, 2021 | 09:16 AM
Hey , the silicone was applied by myself and it may look as ifs created a ramp but it hasn’t , did this to give it an extra seal as I thought it may have been leaking from there but obviously not .
Old Jun 27, 2021 | 09:57 AM
XRAD's Avatar
known issue.....water runs right into cabin intake. ....find a suitable universal weather seal like at autozone, cut to size and silicone to the upper lip of intake, to give a bit of a 'gutter' protection......
Old Jun 27, 2021 | 10:10 AM
XRAD Perspex did it for me 😉
Old Jun 27, 2021 | 12:34 PM
dswilly's Avatar
Oops, meant it looks great! I cant talk, bottom of my transfer case looks similar.
Old Jun 27, 2021 | 10:54 PM
Tony Luna's Avatar
This did the trick for me…
https://landroverforums.com/forum/di...-102055/page3/
Tony Luna
Apr 17, 2025 03:03 PM
RizzleKicks
Jun 28, 2021 02:43 AM
DakotaTravler
May 5, 2019 08:32 AM
marnix
Mar 23, 2019 02:06 PM
Irish4x4
Nov 15, 2010 07:55 PM
