Water leak
Old Jul 3, 2017 | 03:30 PM
OffroadFrance's Avatar
It shouldn't leak into the cab with any plastic scuttle parts missing. Have you checked carefully the 2# (2 front) A/C drain nipples underneath? If they don't leak off on the ground properly the drain tray overflows and saturates the carpet.
Old Jul 3, 2017 | 03:40 PM
Luckyjayb's Avatar
Yea my wife hates it too. But to answer your question off-road France, it is coming from somewhere up there because it's hitting the carpet and the upper portion of the rubber mat. I know it's not a door seal or anything and I can't find anything down that way
Old Jul 3, 2017 | 03:45 PM
The only things I can think of apart from the windshield leaking is the A/C drain tray or the heater pipework to the heater matrix.
PS: The A/C drain tray and drain hose sometimes get blocked up from the drain nipples underneath. Take off the drain nipples and very carefully push a plastic covered curtain stretcher wire up the tube.
Amazon Amazon
It's made for the job.
Old Jul 3, 2017 | 04:16 PM
LR03NJ's Avatar
https://www.amazon.co.uk/Curtain-Wir.../dp/B002Z8N0KC
YES! that could be it. Slow coolant leak around the core. Blower not too strong to blow through the evaporator, clogged and ice build up then melts somewhere where cant catch drip.
But sorry Jason man, got to insert this image again. LOL
Old Jul 3, 2017 | 04:39 PM
number9's Avatar
Cowl on mine is cracked in several place and no leaks noted. Does the debris collection area beneath plastic cowl drain properly? Why not try parking with DS lower and see if it still leaks. Are You using hose/H2O to look for leaks or waiting for rain? Pro WS installs known to leak.
Old Jul 3, 2017 | 10:26 PM
X1 .............. good thinking Batman a hose should emit water onto the ground behind each front wheel via the scuttle drains.
Now Luckyjayb has two uses for his curtain stretchers, he can poke them down the scuttle drain holes
Old Jul 4, 2017 | 05:52 PM
Luckyjayb's Avatar
I think I have found the culprit. The body seam is cracked from it being 17 years old and I believe that's where the water is coming in from. I have hose tested it and that seems to be the issue. Have it all taken apart now and put new body seam sealer on and after that dried, I used flex seal on top of it!!!
Old Jul 4, 2017 | 06:04 PM
mln01's Avatar
Pics?
Old Jul 4, 2017 | 07:50 PM
Luckyjayb's Avatar
Old Jul 5, 2017 | 05:48 PM
Good one Luckyjayb, worth all the trouble in the end.
PS: we had all better take note for the future if water soaks the cab carpet.
earlyrover
Mar 27, 2017 03:41 PM
discoboy
Dec 20, 2012 02:24 AM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
rgrizzard
Mar 6, 2008 10:16 AM
