Water Leak Upper A-pillar (D2)
Old Jul 27, 2018 | 09:19 AM
  #21
ahab's Avatar
Good idea. I know a few I can practice on.
Old Aug 8, 2018 | 08:29 PM
  #22
dgm's Avatar
dgm
What type/brand sealant should I use. I have same issue.
Old Aug 10, 2018 | 02:41 AM
  #23
JUKE179r's Avatar
I jinxed myself!
My driver's side A-Pillar cover is cracked all to hell, the clips pulled away from the windscreen and 2 of the 3 plastic rivets that hold it in tore through the cover.
This sucks. Now I'll replace both of them.
Old Jul 22, 2019 | 08:44 AM
  #24
collector87's Avatar
Hello,
I'm trying to start this repair.
I've taken the A pillar covers off my parts truck - they're in really good shape.
I've got new rivets and clips.
I took this in to a vehicle window shop and they wouldn't work on it - said it needed body fill, that I could use silicon but it would retain moisture and rust it worse.
I've looked at the TSB - says to remove quite a bit but it seems like I can see what I need to seal without removing anything...?
A few questions:
-What sealant do I use?
-How do I reattach the A pillar covers with the clips?
Really appreciate your advice, please see photos of everything below.
Thanks!
Old Jul 22, 2019 | 09:36 AM
  #25
Sandman614's Avatar
I think I finally found the true source of my leak. The water is rolling off the edge and through this opening at the end of the rain gutter near the windshield. I have some Sikaflex 295 uv on the way to reseal the entire rain gutter.
Old Jul 22, 2019 | 10:15 AM
  #26
Richard Gallant's Avatar
I used silicone to fill my driver side no issues since
Old Oct 23, 2021 | 11:12 AM
  #27
604x4BC's Avatar
Are you guys saying if I plug this gap up in the gutters, my headliner won't be wet anymore?
Old Oct 23, 2021 | 01:12 PM
  #28
@604x4BC that will help a lot, also check all around the roof racks and sun roofs. We can meet up one day if you like I am out in the valley, I can show you all the places I went over
Old Oct 24, 2021 | 03:04 PM
  #29
604x4BC's Avatar
Haha.. Obviously a guy from BC would know a thing or 2 about rain proofing!
Thanks, I have to pull the headliner to get redone anyway so I'll get into it soon and start going over it all.
Good timing I suppose
Old Oct 24, 2021 | 04:00 PM
  #30
acg's Avatar
acg
Just re-did the headliner myself and took the opportunity to install the ham radio on the top of the upper console trim by the windshield. I do not live far from Richard (I am in Chilliwack). Let me know if you guys want to get together. I can give a few tips on the headliner re-install.
