Water in passenger footwell: not AC, not windshield
Old Jun 23, 2009 | 11:42 PM
dammad's Avatar
Default Water in passenger footwell: not AC, not windshield
I've got water in the passenger footwell. I cleared out the A/C drains (got out about a pint of water) and dried out the carpet/backing.
However, the following day, its wet again. No A/C use, no rainfall here.
Dried it again and the next day, the water is back again.
Any ideas what is causing it? Any suggestions on how to get the passenger carpet fully up so perhaps I can see where it is coming from?
Old Jun 24, 2009 | 02:28 AM
khuds308's Avatar
check to see if your coolent level. see if it is low.
Old Jun 24, 2009 | 05:41 AM
Feel the water, is it slimy? Does it have a sweet smell? Does it have a bitter taste?
Old Jun 24, 2009 | 08:10 AM
You may have fixed the cause, the drains, but not the problem. If you don't pull up the carpet and the pads, removing all the water and letting it dry out before laying them down, the water will remain and mold will grow.
Old Jun 24, 2009 | 10:15 AM
okdiscoguy's Avatar
Take the trim off the door wells and lift up the carpet. Put a couple of bricks under it and let it dry out. Like Mike said, if you dont let it dry underneath, it will mold.
Might have to clean the drains a little more. I had to take them off the metal tubes inside the truck and spray water down them. They were really dirty.
Old Jun 24, 2009 | 02:20 PM
dammad's Avatar
The coolant level does not appear low and the liquid is more 'musty' and not sweet smelling.
I put a bulk pack of Cokes on it with a towel underneath to dry things out and have left a fan under the carpet for 6-8 hours.
I guess as okdsicoguy mentions I'm going to have to take off all the footwell trim to get the carpet fully up. Currently I just have the door/floor trim off.
Old Jun 24, 2009 | 04:33 PM
okdiscoguy's Avatar
You are good enough on the carpet, that is what I was talking about. Just so you can get air under the carpet. This is where mt drains connect inside. A D2 may differ slightly, but same basic idea.
If you have not had any rain, it is either coolant (sweet smell) or those drains (there are 2).
Attached Thumbnails Water in passenger footwell: not AC, not windshield-img_0758.jpg
Old Jun 25, 2009 | 01:08 AM
dammad's Avatar
Thanks. I'm going to have a go at the drains again to be sure.
gunsanroses91
Aug 12, 2015 08:34 PM
joshrave
Dec 12, 2014 01:08 AM
stevewarne
Sep 4, 2010 07:30 AM
no limit
Sep 12, 2007 11:32 AM
luckydog
Oct 12, 2006 04:35 PM
