Water pump or?
Old Feb 18, 2011 | 03:05 PM
tnridge's Avatar
8th Gear
Default Water pump or?
2000 discovery two. Replaced thermostat..cleaned out everything...fixed leak at throttle body heater plate..etc...have pumped up and put pressure on it and did that test. You can run for three minutes and it over heats. Dont seem to be head gaskets. My mechanic says it's definately not that. Thye water wont circulate. IS it the water pump? What do you think?
Thanks in Advance.
Steve
Old Feb 18, 2011 | 10:34 PM
willrok13's Avatar
You're not losing coolant? You have pressure tested the motor and it is okay? If you answer yes to both of those it's probably not the head gaskets.
How many miles are on your truck and has the water pump ever been replaced? How do you know you're not circulating coolant? If you are not circulating coolant then I would think the water pump is the logical next step. You could have a cracked block -- or at least you WILL if you don't stop overheating the motor. When you say your truck overheats, does it boil over or do you just notice the temp rising? If the water pump is okay you need to administer a chemical test to see if combustion gases are escaping into your coolant.
Old Feb 21, 2011 | 03:53 AM
tnridge's Avatar
8th Gear
114000 miles and bought it used. It appeas that the pump has never been replaced. There is not one coolant leak. He pumped it up and did the pressure test and rulled out the head gaskets, He's the one that says the water and antifreeze is not circulating. He also says the blockis not cracked due to his knowledge. I ordered a water pump. It's under a hundred dollars so it will be here tomorrow and we shall see.
Thanks for your input.
Old Feb 21, 2011 | 07:45 AM
Bundu's Avatar
Banned
Check if the heater core is clogged.
A5scott
May 18, 2015 06:34 AM
discoboy
Dec 20, 2012 02:24 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
