Water temp and Oil pressure gauges
Old Sep 3, 2015 | 04:29 PM
Daedrix's Avatar
Banned
Default Water temp and Oil pressure gauges
So i finally installed my Oil pressure and Water temp gauges. The first pic is with them installed but not hooked up to the sensors.
This is with the sensor hooked up and this is the idle oil pressure:
This is the max pressure at WOT:
Sandwich adapter with MANN filter:
I haven't installed the Water temp sensor yet but when i do ill update the thread.
Old Sep 4, 2015 | 05:38 AM
antichrist's Avatar
I'd swap positions, so the most critical, temp, is lower so you don't have to take your eyes off the road as far to read it.
Just an FYI on the filter. From what I can find online MANN has a poor design, the bypass valve is in the dome end, so if it goes in to bypass mode the oil going to the engine is passing over all the crud in the bottom.
Old Dec 4, 2015 | 03:46 PM
RSDEVIL's Avatar
Awesome...!!! Where did you find the pod for the pillar to mount them...???
Old Dec 5, 2015 | 08:22 AM
Daedrix's Avatar
Banned
Its just a universal A-Pillar 2 pod mount.
Tony Luna
Aug 21, 2015 08:56 AM
san988
Oct 9, 2013 08:02 PM
eitydeuce
Mar 20, 2013 01:12 PM
Bryan H
Oct 23, 2011 08:03 PM
Snafu / Disco Fries
Feb 24, 2011 09:10 PM
