which weight oil should I use?
Old Aug 21, 2011 | 06:42 PM
  #21
Originally Posted by timdunbar
Wow dudes 5000 miles? I go 3000 miles or 3 months, and I usually don't get 2000 miles on mine. I either use Rotella 15w40 or Mobil Delvac 15w40 whichever is on sale, and I use O'reilly's oil filter for the M1-301. I can usually do an oil change for $24 as when either one or the other oil is on sale I buy all I can. Once a year I throw in a bottle of Rislone. Rislone is currently on sale at Advance btw.
Its your money, but you are wasting it.
I go 5,000 miles and use NAPA oil filters.
If I didnt use Rotella then I would go 3,000 miles.
Old Aug 21, 2011 | 06:49 PM
  #22
DiscoRover007's Avatar
I'm going with Rotella 15w-40 from here on out. As I've told Spike before, I noticed a huge difference when I made the switch. The engine was running much quieter.
Old Aug 21, 2011 | 06:59 PM
  #23
Kalel's Avatar
Time to switch.
Old Aug 21, 2011 | 09:59 PM
  #24
Discovery_Scott's Avatar
Okay, I am definately doing the oil change tomorrow, gonna go with the Rotella 15w-40. I hope all goes well, because I just found out I'll be making a round trip out to NorthEast PA which will be about 2,000 miles over the next week or so, and this will be the largest road trip I've taken my DII on. I sure am glad that I've had the support of the members of this discussion board to deal with past issues, and I can't see anything that could be a major problem for this trip.
Old Aug 21, 2011 | 10:17 PM
  #25
If you will have a laptop with you, take the RAVE. If not, take RAVE on a usb memory drive. You never know. Might also be time on the trip for a quick pass at a good salvage yard, most are on-line.
Old Aug 22, 2011 | 04:01 PM
  #26
Banzai Jimmy's Avatar
Originally Posted by DonRW2007
You guys (and gals) have too much time on your hands. And, you've fallen into the trap of placing too much credence into the oil company's marketing. Oil is pretty much oil. It's not gonna make or break your engine's performance. Pick one, keep the level between the high and low level marks, and get a life!
Old Aug 22, 2011 | 07:23 PM
  #27
Originally Posted by banzai jimmy
:d
nice!!!
Old Aug 22, 2011 | 08:43 PM
  #28
BITOG ftw.
Old Aug 22, 2011 | 10:44 PM
  #29
Rover_Hokie's Avatar
FWIW, I run Amsoil full synthetic European 5W-40 that meets the D2 specs with extended drain intervals and oil analysis using the Amsoil oil filter year round. Running mine 55K now this way. I did an Amsoil flush when I bought it used, and then at 5K for first change (little more dino oil crude may have been loosened up since the flush, so wanted to get it out of there) and then based on oil analysis since then.
To each there own. Find something that makes your rover run smooth and meets specs and does not give you hard starts in the winter. Have some logic for why you use it. Check it regularly that it is full and that it can still do what is is suppose to do to protect your engine, and change as necessary oil/filter regularly based on your plan.
Old Aug 22, 2011 | 11:29 PM
  #30
hunter's Avatar
Stock filter and Castrol 10w-40 mineral. Do it regularly and don't over-think it.
Dave
