weird happening when turning at high speeds.
Old May 4, 2008 | 11:03 AM
Darover's Avatar
Default weird happening when turning at high speeds.
Guys, here's another question I was meaning to ask, but it happens very rarely and I keep forgetting. But it happened last night and here it goes....
ONLY when taking tightly curved off-ramps or overpassat highway speeds, and as said this rarely happens, I get the same noise and feeling ( shake)in the steering as one would get if driving on those tracks on the side of highways that are meant to wake up a sleepy driver if he gets out of line ( or a gravel roadfeeling)you know...RRRRRRRRRR only when turning the steering. Thought it could be ACE related ( fluid changed last year), orfront axle or CVbut it only happens once in a while and on the situations discribed above ????
WTH ??????
Old May 4, 2008 | 11:21 AM
Default RE: weird happening when turning at high speeds.
How many miles on your truck?
Sounds like a tiie rod end or one of the steering componet ends. Have you ever replaced your steering stabilizer?
Old May 4, 2008 | 12:29 PM
Darover's Avatar
58000 miles, I know my upper left tie rod end was a bit loose last year and although not alarming per the say of the alignment specialist, it was a year ago so it could have loosened up some more. The front stabiliser is a OME that I installed at the same time as my OME suspension last year. I checked it for thightness and all is O.K.
I'll look into that tie-rod thing,
Many thanks.
SCIGONE
LR2
Nov 26, 2018 12:09 PM
omarica7
Mar 11, 2014 08:12 AM
jljde
Mar 19, 2013 12:56 PM
maudlinp
Dec 29, 2010 07:19 PM
bangkuaidiscovery04
May 11, 2009 10:00 PM
