Weird noise
Old Jul 1, 2013 | 10:00 AM
Zimthejeepman's Avatar
Default Weird noise
I am getting a weird noise from the front left of the Discovery. It almost sounds like tire howl from the tires but is slower then the tire speed cadence. It is a "woom woom" sound at the cadence of digital alarm. I replace the front driveshaft, I tested the wheel for play, doesn't change speed with gear changes or putting it in neutral. Any ideas?
2003 Discovery HSE7
Diff lock converted
2" lift
New front driveshaft
New water pump/ 180 stat
36,000 miles
Old Jul 1, 2013 | 01:17 PM
clanch's Avatar
Wheel bearing hub? Drive it, turn the wheel left and right the sound change when load
unload the bearing.
Old Jul 2, 2013 | 09:43 AM
Thanks I will try that.
redbaron586
Nov 16, 2008 10:06 PM
tonyp71
Jan 13, 2008 08:46 AM
newBrover
Oct 16, 2007 05:57 PM
johnnybob06
May 29, 2007 08:52 AM
msbont
Sep 10, 2006 03:53 PM
