wet floorboard but not...
Old Nov 6, 2007 | 06:21 AM
dr.rover's Avatar
7th Gear
Default wet floorboard but not...
Dear Roveristas,
My passenger floorboard is soaking wet, checked the a/c drain underneath and its not clogged.
I lifted the carpet and cut out the passenger floor board and did some spot rust conversion with primer.
The following day it rained and lo and behold, the passenger floor had a small pool of water. It seems to be trickling from the side of the body.
Cant seem to figure out where it was coming from unless I remove the dash. I was thinking that the windshield seal is the culprit.
Help, what should I do?
Thanks.
Old Nov 6, 2007 | 07:26 AM
Default RE: wet floorboard but not...
2 possible reasons, the most common reason would be a plugged or dislodged drain tube from the front sun roof. The second possibility would be a seal that has failed on your windshield.
Old Nov 6, 2007 | 07:33 AM
dr.rover's Avatar
7th Gear
So I guess its a failed windshield seal because I dont have a sunroof.
Can I just fix with a sealant?
Thanks.
Old Nov 6, 2007 | 08:32 AM
That would make since.
Old Nov 6, 2007 | 10:16 AM
98roverguy's Avatar
Get you a big bat, smash your windshield. Call a local windshield replacement company and have them put in a new windshield for free as insurance covers it. They will replace all seals. The bigger the bat the better.
Old Nov 6, 2007 | 06:19 PM
dr.rover's Avatar
7th Gear
Thanks I might just do that if all things fail.
honda50r
Jan 2, 2012 07:09 AM
knac1234
Jul 25, 2009 09:56 AM
Disbet
Jun 20, 2008 06:59 PM
rsandmeyer
Jun 18, 2008 06:48 PM
biz1285
Feb 5, 2006 05:20 AM
