What Bolt is this?
Old Dec 3, 2011 | 03:59 PM
04BluDisco's Avatar
2 MPG? that's pretty impressive... I was actually wondering where the globs of RTV go, but I will look at the gasket kit. I presume either british pacific, or rovers north are the way to go? Could you actually hear a difference in how the motor ran as well? also, did you take your spark plugs out to get the gears aligned, or just leave them in and crank on the crank shaft bolt?
Old Dec 3, 2011 | 04:14 PM
04BluDisco's Avatar
Also, are you guys usually replacing both gears and the timing chain, or just the chain?
Old Dec 3, 2011 | 05:39 PM
Rovin4life's Avatar
actually that bolt comes loose because the oring gets hard as a rock and leaks like a sieve. We just take it down and put an new oring and some pipe sealant. never leaks again.
Old Dec 11, 2011 | 07:14 PM
04BluDisco's Avatar
In looking at this more with the bottom plastic cover off, I can't tell if it's coming from the front crankseal, or potentially the steering box.... since I have had the plastic cover off for a couple weeks, it hasn't leaked a drop, but it has a fair amount of dirt and fairl fresh oil coating the oil sump pan, all the way back..
Old Dec 13, 2011 | 10:04 AM
shanechevelle's Avatar
On an 02 The top gears points down and the bottom gear points up. Just line them up. There is a key way on the crank so the gear can only go on the way it is. It also just comes right off with your hand. No tool needed.
I didnt take any plugs out, I just turned the engine by the bolt, and then used my air gun to pull the bolt back out.
I used factory parts...bought at our local LR dealer. Wasnt too bad and the help they give you in person, advice, is worth more then waiting on parts in the mail...
Old Dec 13, 2011 | 10:05 AM
I replaced both gears and the chain.
GET AN OIL PUMP KIT.
on the inside of the cover there are some large head screws (#3 I think) that hold the oil pump into the cover. Take those screws off and check your pump...most likley it will be cracked which limits the amount of oil flow...
There are a few pics here of a cracked oil pump...look around you will find them...
Old Dec 20, 2011 | 09:46 AM
04BluDisco's Avatar
I have used Miami Rovers Ebay store on a few items with good luck... given Disco Mike'e comments about using OE parts, I went to their site and looked at the manufacturer... Says "All PArts" England. Anyone used them before?
LAND ROVER TIMING CHAIN SET SET KIT DISCOVERY II 2 RANGE P38 00-02 MR0015 ALLM | eBay
Old Dec 20, 2011 | 10:37 AM
buick215's Avatar
It's not All Parts it's All Makes. They are not OEM they are aftermarket. In terms of quality most of their parts are ok.
Old Jul 8, 2022 | 04:28 PM
Andy23's Avatar
I took off the engine shroud below the engine so I could more easily see the suspected from crankseal lead, and I notice a large bolk right next to the oil filter housing that wasn't completely seated. I attached a pict. Does anyone know what it does, and if it should be seated, what Torque?
(as you can see from the pict, the motor is getting a good leak up front there, so I am planning on fixing the front crank seal, water pump, oil pump. Possibly the timing chain too, but not sure on that one... any thoughts on that?) Also, in looking at it, it appears the front of the timing cover actually mates to the oil pan... any issues with causing more leaks by pulling the timing cover off?
Thanks!
did you figure out what bolt that was ?
I would say this is the same bolt on my 2004 and it appears to be leaking .
Old Jul 8, 2022 | 06:31 PM
Extinct's Avatar
Oil cooler port block off bolt.
