What is this bracket/shelf for on a 2004 D2
Old Apr 7, 2013 | 01:48 PM
1danger1's Avatar
Default What is this bracket/shelf for on a 2004 D2
I recently replaced my stock front prop shaft and while underneath found this shelf/bracket with my head, after a few choice expletives took a closer look. It almost looks like a battery shelf. Does anyone know what its for. It is on the driver side between the front and rear door on the outer frame. Only the driver side has one. Also there are 2 welded rings on the frame. One on each side what is their purpose?
Attached Thumbnails What is this bracket/shelf for on a 2004 D2-img_1504.jpg
Old Apr 7, 2013 | 02:10 PM
That bracket was for the SLS pump for your rear air suspension which you no longer have.
bballjames's Avatar
That is the space where the air compressor goes on trucks with SLS.
Old Apr 7, 2013 | 03:17 PM
1danger1's Avatar
Thanks, was thinking about mounting a remote battery for a power inverter. anyone know what the two welded rings on the frame are for?
Old Apr 7, 2013 | 03:54 PM
ZGPhoto's Avatar
The front and rear rings are towing tie downs.
RJJM
Mar 16, 2014 02:31 PM
RJJM
Feb 12, 2014 07:29 AM
grandkodiak
Feb 3, 2014 02:57 PM
earlyrover
Aug 8, 2013 05:36 AM
pilsner
Aug 30, 2008 11:12 PM
