What CB coax wire fits through washer hole?
Old Aug 18, 2012 | 06:13 PM
wyrdvans's Avatar
Default What CB coax wire fits through washer hole?
I'm looking to fit a cb antenna to the rear tire carrier but before I purchase one I want to know which cable will fit through the washer fluid grommet.
Here's the kit I'm looking at: No Ground Plane Mirror, Rail, or Side Mount Kits by Firestik<SUP>®</SUP>
Has anyone used it? Does the cable fit through the hole?
Old Aug 18, 2012 | 06:50 PM
jfall's Avatar
Breaker good buddy.
There is a thing called a cell phone...
Use RG174 or similar.
Do NOT use RG58
RG-174 50 Ohm Coax Cable Military Spec very thin diameter - per - Radioworld
Old Aug 18, 2012 | 07:02 PM
You will probably need to drill the hole out, if so, then buy a rubber o-ring bushing that will fit tight on the cable and larger enough to seal the hole.
Old Aug 18, 2012 | 11:16 PM
oilspotLR's Avatar
Just don't forget spring for the antenna!
Old Aug 19, 2012 | 06:34 AM
re: There is a thing called a cell phone
I thought the best trails were where you had no bars.... lol
Marni
Jul 12, 2013 02:00 PM
audiS4S6
May 6, 2010 12:14 PM
krazzz
Jan 15, 2010 07:17 AM
yarddawg
Mar 13, 2008 10:14 AM
Groucho
Apr 28, 2006 07:06 PM
