Old Feb 7, 2014 | 04:32 PM
  #1201
Sophia Buscemi's Avatar
4th Gear
Smile
Originally Posted by dcarr1971
Haven't moved mine on over week since I broke a motor mount and the fan exploded. (The fan took out the radiator, upper shroud, coolant return line, air box, and parts of the fan tried to punch up through the hood.). Then the shaft on the PAS pump decided to walk out about 4mm and shreaded the belt, so...
...in the last week I've done the following:
- Replace the radiator, fan, fan clutch, cooling return hose.
- Flushed and bled the cooling system.
- Replaced 2 motor mounts.
- Made a custom, 5-rib belt to get the truck home when it tried to slice 2 ribs off the existing belt. (All I did was trim the rest of the 2 ribs off, but I did it on the side of the road in the middle of the night!)
- Pulled and replaced the PAS pump with a brand new one.
Today,
- I'm re-bleeding the cooling system (temps just weren't stable enough for my liking before the fiasco with the PAS).
- Bleeding the PAS pump.
- Maybe (time permitting) replacing the rear drive shaft with a u-joint rear drive shaft. (I'm just tired of wasting $$$ on rotoflex couplers.)
Land Rover Service Greensboro | Land Rover Greensboro, NC
Old Feb 7, 2014 | 05:08 PM
  #1202
ZGPhoto's Avatar
annnnd spam
Old Feb 8, 2014 | 04:54 PM
  #1203
roverwoody's Avatar
Added an Edge Star 63qt fridge/ freezer. I had an 80qt before in my old rig. They hold up really well.
Old Feb 8, 2014 | 05:04 PM
  #1204
jalodge's Avatar
Originally Posted by Dane!
Rained a little today, tried using my wipers to just clear the windshield, and they made it worse. I didn't want to buy new wiper blades from the interweb, so I went to AutoZone and bought some Bosch 21'' Blades and swapped the rubber pieces onto my the LR frames. Took 15 minutes and some finesse, but they work great.
What Bosch Blades did you use?
Old Feb 8, 2014 | 10:03 PM
  #1205
ScreamingLife's Avatar
Finally got around to replacing the t-case shifter boot and the parking brake boot and it was totally worth it. They are quite snazzy and totally recommended, they make your car look much newer.
Old Feb 8, 2014 | 10:51 PM
  #1206
SuperSport's Avatar
Where did you get yours? I'm considering this lately.
Old Feb 9, 2014 | 12:05 AM
  #1207
I ordered them from RN. They look pretty good. Only took about an hour and that was mostly because I couldn't find "ammo" for my glue gun.
Old Feb 9, 2014 | 12:30 AM
  #1208
Dave03S's Avatar
You can throw those rubber mats in the dishwasher and get rid of that "sticks and stems" look too.
That makes it look even mo betta
Old Feb 9, 2014 | 08:31 AM
  #1209
dusty1's Avatar
good idea. easier than soap and brush and hose.
Old Feb 9, 2014 | 12:44 PM
  #1210
SuperSport's Avatar
Fantastic Idea. I do that with a lot of other things, never thought about that for these.
