Old 03-29-2014, 10:26 AM
akatravz's Avatar
6th Gear
Originally Posted by ZGPhoto
Links not working, did you get steelies?
Eh, ill try to fix the links later, but yeah the black vented steelies. Getting them put on Monday!
  #1492
Old 03-29-2014, 11:24 AM
landry81's Avatar
4th Gear
Tried to figure out why my 03 LR Disco has a misfire on cylinders #3 #5 #6 and #7 but starts up and will idle (idle low) but idle non the less any input would be great. I just bought it.
  #1493
Old 03-29-2014, 11:38 AM
jafir's Avatar
Different banks, different coils. Maybe just a tune up with plugs and wires?
I think 6-7 might be paired together on the coil with the wasted spark, so maybe a bad coil too? Going to need some good old troubleshooting.
  #1494
Old 03-29-2014, 03:16 PM
sstevensonm's Avatar
Default Parts
I have a parts car if u r needing any used parts for ur sunroof let me know
Originally Posted by zeroone
Just finished removing the headliner. Both front drains broken off.. surprise. Rear ones are loose. Rear motor seized. Front still works. Ill.be buying a couple used ones off of evilbay just to have. Headliner will go for recover once all leaks and possible leaks are repaired. Any suggestions on possible leaks I should fix regardless?
  #1495
Old 03-29-2014, 04:07 PM
ls1morethanyou's Avatar
Originally Posted by jalodge
What kind of bumper is that?
its a Bottorff bumper. i got the tuck with it, but apparently the guy was a POS and screwed over alot of LR guys.
  #1496
Old 03-29-2014, 05:47 PM
zeroone's Avatar
Thank you very much. If i need anything I definitely will. So far everything came out without a hitch. I'm kinda shocked. I usually break all kinds of stuff. Lol.
  #1497
Old 03-29-2014, 06:24 PM
Dane!'s Avatar
x2 on the breaking of things.
  #1498
Old 03-30-2014, 08:50 PM
Street Wolf's Avatar
Cleaned things, and experimented with making new more durable shifter boots.
(The handbrake one hasn't been done yet, obviously)
  #1499
Old 03-30-2014, 08:57 PM
ScreamingLife's Avatar
I really like that shifter boot.
I just installed the extended ABS lines. Holy crap they really do extend the lines. I guess if I lift the D2 another foot I should be good to go.
  #1500
Old 03-30-2014, 09:59 PM
zeroone's Avatar
I'll second the shiftboot. Really nice. Is it nylon?
Quick Reply: What did you do with your DII today?
