Old 12-16-2014, 01:27 PM
Received 1,512 Likes on 1,239 Posts
I sat and cussed the fan clutch some more. Need to order that pulley holder tool.....
  #2372
Old 12-16-2014, 01:55 PM
dusty1's Avatar
hehehehe. sorry. if you have some steel (1.5 - 2"....doesn't have to be thick) laying around....its just 3 holes drilled for little bolt heads and a notch. I made one a long time ago out of 3/16 thick 2"x 12-16" piece. just notched for shaft, put a paint blob on the 3 little bolt heads, pressed the piece to it, drilled out the transferred paint marks and it fit fine.
  #2373
Old 12-16-2014, 07:15 PM
lordmorpheus's Avatar
*Finally* finished my valve cover gasket job and have it back in my own driveway. No more coolant leaking from the back of the engine because the seal on the heater pipe to manifold is the wrong size causing coolant to pool on the manifold and then run to the back of the engine. $1.50 from the usual suppliers (plus freight) but I remembered Carquest can order from WorldPac overnight and no freight, so I ended up paying $3.12 for the seal. Topped off the coolant and verified no major leaks, then finally replaced the alternator, managing to break the smaller wire from the mounting nut because everything is hard as a rock from engine heat. Solder a longer wire to the captured nut, and the other end to the short section from the harness. Don't worry about heating the heat shrink because I know the engine heat will take care of that.
The heated seats have never felt so good as I was frozen to the core.
  #2374
Old 12-16-2014, 08:53 PM
DiscoDubs's Avatar
Originally Posted by ZGPhoto
Marty powell sells diffs for $70 shipped FYI
And since your cross pin decided to shoot out of the axle housing, like mine did, you'll just have to weld it up.
ichopimports@yahoo.com
$70 is cheap, I'll keep that tucked away for future reference, thanks. I changed out the front today, the rear was too warped, the fill plug wouldn't seat properly anymore so I decided just to replace the whole axle assembly. I figure I'll atleast have the added bonus of a spare set of axles and hubs.
  #2375
Old 12-16-2014, 10:06 PM
dusty1's Avatar
I figured out why you don't buy a linexed bumper from some dude on the forums.
Even though it was sold as a cheaply priced Greg Davis rear bumper that had been fitted to his D2 and welded up and linexed.
It was really three pieces of metal that were welded together. They were line x coated but that was pointless. The very smart person had them welded up without ever fitting them to any vehicle whatsoever. It look like a curb feeler at the top part of my tires. It's stuck out on either side of the body at about 6 to 8 inches.
What I actually did was waste $600 on a piece of thin wall rectangular tubing with a receiver hitch and a plate attached to it. The rest had to go in the trash and by the time I was finished welding on new pieces all the Line x melted off.
Jokes on me!!!!! Thanks for full disclosure, Buddy!!!!
  #2376
Old 12-16-2014, 11:16 PM
ls1morethanyou's Avatar
i busted a nut or sockets... i mean 6 sockets trying to remove the last head bolt.
  #2377
Old 12-17-2014, 08:22 AM
ZGPhoto's Avatar
How is $600 an inexpensive GD bumper!?! He sells them direct for like $500
  #2378
Old 12-17-2014, 08:27 AM
dusty1's Avatar
with shipping from nyc and line x, ready to bolt on. the line x was the reason I wanted it
more like$560 .....I rounded up because I am being a sore loser
  #2379
Old 12-17-2014, 09:35 AM
ZGPhoto's Avatar
Damn, sorry man! That sucks
  #2380
Old 12-17-2014, 09:50 AM
dusty1's Avatar
thanks. it happens, when you buy stuff from unknown sources. always a gamble. and if anyone is curious that line x junk burns really easily...stinky, black smoking, probably toxic, melting plastic junk. and once the metal is heated it has no more adhesion afterwords....actually pretty easily removed if you get it hot with a little propane torch first. I guess I paid for a learning experience
Quick Reply: What did you do with your DII today?
