#2671
#2672
I use these for the inside x3
2X Festoon T10 BA9S Cool White LED 48SMD Panel Interior Dome Map Light Lamp 12V | eBay
Thats with two of those, now it has three and one of those lights for the LP
then i used this one for the LP since i had extras i was going to use as rock lights
6 x 12V White 48SMD Panel Festoon T10 BA9S Interior Dome Map LED Light Bulb Lamp | eBay
What i did was put hot glue on top to seal out the water and they hold up great! the reason i had to swap the original one out was i am sure i kicked it while getting on the ladder because it stuck out a little.
#2673
had two recoveries today, dodge ram 1500 and an f250 that sunk to its frame. for the f250 one my rover had an xterra as an anchor and i drug us both closer trying to winch out, then i had an f250 as an anchor diesel and drug us both so then the f250 had a jeep and still drug us forward. another jeep pulled up and the xterra got behind it and with both of us winching we drug the vehicles again till an f150 anchored to the xterra.
good times!
i am the top left
my roof rack leds
good times!
i am the top left
my roof rack leds
#2674
I bought a brand new iPhone 6 last monday, so I figured it was about time to replace my broken DC outlet so i can charge the damn thing while I'm driving. I ordered one from LRNJ's Amazon store on Thursday, and it arrived today. Maybe took me an hour tops to get the old one out, tweak and solder wires on the new one a bit, and get it reinstalled. If you have small hands like me, you can manage the whole project just by maneuvering your hand under the dash panel in the passenger footwell.
#2675
In the aftermath of my AC drain line overflow, I finally concluded that the carpets were dry enough this morning to reassemble everything (kick panels & new tread plates / screws). I've had some pans of Damprid stuffed under the foam to suck moisture out of the foam for about 2 weeks now coupled with a dehumidifier I've been running in the truck every night.
Those lines are too easy to clean, so do it right now and save yourself the headache of wet carpets!
#2676
Yesterday: discovered a pretty bad diesel leak, discovered the seal around the diesel pump was bad so replaced which fixed the leak.
Today: sealed 2 holes either side of the windscreen, top corners, where water was pouring in and soaking the headliner. Headliner was also hanging off so with some textile adhesive spray, stuck it back.
Tomorrow: fix my parking sensors
#2679
Working on my winch install
My daily driver I want a winch on for relative light use. I made good progress on the project. I took the winch apart to rotate the clutch handle to an easier to grab angle (due to being mounted under factory bumper) while it was opened up I added a good bit of marine grease to the moving parts, some rtv on the seals/joints for better protection. I've got to finish my mounting brackets this week and then will be ready to finish install and wiring.
#2680
