Old Dec 7, 2016 | 02:17 PM
  #3501
G150driver's Avatar
Used the winch to pull a nice couple in a new Subaru out of a snowbank.
Old Dec 7, 2016 | 04:27 PM
  #3502
Alfa75's Avatar
Default Replaced my leaking radiator!
Finally got my new radiator shipped yesterday afternoon and installed it last night. Mine started as a slow leak that quickly because a stream from where the end cap meets the core on the lower passenger side. Soaked the fasteners down with PB blaster over the weekend while I had the grill and headlights out, so it went in without a hitch.
Old Dec 7, 2016 | 07:24 PM
  #3503
Twix's Avatar
Had a code pop up today. Hill descent control - short or bad ground in the stop lamp circuit is what my OBD reader tells me. No numbers, just the text. Think it's just a bad switch at the pedal?
Old Dec 8, 2016 | 12:26 AM
  #3504
Dave03S's Avatar
Bad brake light switch would disable gear shifter movement. If you ever can't get it out of park, this is the problem.
Did you check your brake light bulbs/fuses? Otherwise I don't have any experience with that code reader response.
Old Dec 8, 2016 | 10:27 AM
  #3505
Steve517's Avatar
Default Celebration
My 2000 Disco turned 100,000 yesterday. Party hats, balloons and a big cake. It was quite a celebration. Today the three amigos showed up. You can't beat that kind of timing.
Old Dec 8, 2016 | 12:57 PM
  #3506
LR03NJ's Avatar
Default Got my reward today!
Got my reward today for getting it right this time!
Old Dec 8, 2016 | 07:44 PM
  #3507
Twix's Avatar
All my brake lights work, even when HDC is operating. HDC also operates just fine. I'm thinking I have a loose ground somewhere because the HDC light comes on and turns off intermittently.
On another note. I changed every exterior bulb on my truck since a bunch were burnt and others were dull and due for replacement. What do the little peanut bulbs at the bottom of the main headlamp housing do exactly? I thought they might be for DRL which my truck should have (Canadian law) but they don't do that. They only come on with low beams
Old Dec 8, 2016 | 10:43 PM
  #3508
Robert Booth's Avatar
The donor p38 4.6 in my D2 just hit 100k and dutifully developed a front cover leak. It soon became
obvious that the headgaskets had let go between rear of the engine and the firewall.
Sweet timing right before Christmas! The silver lining is that I'm going to powder coat the valve covers and get the headers ceramic coated and doing everything at once should have me buttoned up for some time into the future.
Time to clean up the Plenum and valve covers.
Might as well do the timing chain and oil pump while at it.
Frustrating.
Old Dec 9, 2016 | 09:13 AM
  #3509
mln01's Avatar
Originally Posted by Robert Booth
... doing everything at once should have me buttoned up for some time into the future.
Uh oh. You're jinxed. The rover gods do not like thoughts like this being expressed, especially publicly.
Old Dec 9, 2016 | 12:28 PM
  #3510
CPTLOU's Avatar
With regret, I have decided to put my 03' SE in the chopping block and focus on finishing my 00' TreK.
It runs super but I lost my storage and I just cannot do $250 per vehicle per month ( and I had five vehicles in there ).
Attached Thumbnails What did you do with your DII today?-20161005_131100.jpg   What did you do with your DII today?-20161005_131038.jpg   What did you do with your DII today?-20161005_131540.jpg   What did you do with your DII today?-20161005_131529.jpg
