Old Dec 12, 2016 | 05:05 PM
  #3521
The Deputy's Avatar
We got a light dusting of snow last night (10 inches), so roads were sloppy with salt and slush. Washer hadn't been working , but never had a chance to check it out. However, since I'd removed the stock front bumper, for replacement, the washer bottle was now hanging out in the plain view...and it was empty.
Added washer fluid...bingo-bango...clean windshield.
My type of fix...lol.
Side note...the 01 plowed through two foot drifts easily and handled "getting out of the ruts" better than expected, considering the length of the wheelbase. My old Jeep would've been doing donuts after doing some of the same maneuvers the Discovery made today.
Brian.
Old Dec 13, 2016 | 05:42 PM
  #3522
Evansjosephm's Avatar
8th Gear
Default Uni ***** went out
GBR saves the day. Should have my bilstein 7100 remote res's up and running in two days
Old Dec 13, 2016 | 06:20 PM
  #3523
CPTLOU's Avatar
Default 03' sii se 123k ca rover since new
Originally Posted by ThisRoverGuy
How much? And where's it listed?
Asking for a friend
$5000.
I put a brief listing in the classifieds here in the forum.
Your friend can call me directly if seriously interested.
Louis
(650) 430-4660
Old Dec 17, 2016 | 11:57 AM
  #3524
TjTalan's Avatar
Transmission filter and fluid, Oil change and right front window regulator.
Old Dec 18, 2016 | 10:07 PM
  #3525
Street Wolf's Avatar
Old Dec 19, 2016 | 04:00 PM
  #3526
JUKE179r's Avatar
Today I merged "Myrtle" (my Disco) into traffic from a dead stop and I chirped the tires when I romped on the gas. My wife looked at me in shock and asked if it was Myrtle that made the noise. I said "I thinks so" and then we high fived each other.
I'm sure when I drive Myrtle tomorrow I'll have error codes and fault lights up the wazooo and also be 5 gallons less of gas from that experience.
Old Dec 19, 2016 | 04:23 PM
  #3527
jastutte's Avatar
Originally Posted by Street Wolf
did you swap new head lights in or use a cleaner on the plastic? if a cleaner which one?
Old Dec 19, 2016 | 07:21 PM
  #3528
KernowDiscovery's Avatar
lol.. glad I'm not the only one that talks to my spouse in the Rover about the Rover.. I pushed down hard on the brakes yesterday to see what would happen (testing out the driving conditions....) and even though I have the 3 amigos all lit up, the ABS system started chattering and pulsating up a storm. I was able to stop and stayed stopped so that was ok.. I think...
Bertha (my Disco) is a make-shift sleigh this time of year. There has been SO much snow lately that it makes traveling an adventure - never know where I'm going to end up next or if I should be there - haha.
Old Dec 19, 2016 | 10:11 PM
  #3529
Cleaners do not work. You have to sand them. Generally starting with 1000 grit and working your way up to 2000 grit, finish it off with rubbing compound, then polishing compound.
Old Dec 20, 2016 | 09:46 AM
  #3530
04duxlr's Avatar
Your headlights look great, but they're not likely to stay that way. The reason that they turn yellow is because the protective coating on them from the factory gets worn off and the UV rays from the sun then make them discolored. The lenses need to have a coating on them or they will just turn yellow again. You can wax them every week which might work, or you can just sand them with 600 grit then spray them with a quality clearcoat and they will stay clear for a long time.
