Old May 31, 2017 | 03:04 PM
  #4051
CollieRover's Avatar
I am visiting my parents, have a garage so bedlinered my fender flares, ladder, and wipers. replaced Power steering pump and flushed the system. Sanded and clearcoated my headlights a la chrisfix on youtube.
Went well, got some overspray on my car as some newspaper became undone, but he flares and everything look much better. Not that anyone but myself will notice.
Old Jun 1, 2017 | 09:28 AM
  #4052
zoltan7's Avatar
no idea how you changed that pump and it isn't groaning. I'm battling mine hard currently
Old Jun 2, 2017 | 01:41 PM
  #4053
This is the second time I have done it. Are you sure it is the pump that is groaning. TBH, my steering has been getting worse and worse, and I think it has been my steering box the whole time.
Old Jun 2, 2017 | 02:21 PM
  #4054
zoltan7's Avatar
I think it's the pump. I'm going to rebuild my old pump and try a few things on this new one to get her to smooth out. I think maybe just a tiny bit of air in the system somewhere (or a stiff seal)
Old Jun 2, 2017 | 02:49 PM
  #4055
JUKE179r's Avatar
I had a blown rear crankshaft seal which I honestly think was due to excessive pressure from adding a second FRAM PCV valve to the left side (drivers side) of the Bosch 4.0 engine. So a second $4 FRAM PCV valve cost me $750 plus down time driving Myrtle.
Possibly because of this additional PCV and additional bac pressure, my engine rear crank shaft seal is pissing out oil. Luckily the maintenance shop owner asked me what else I needed done since he would be working on it for a day. So he ended up replacing my modded front driveshaft and bolts/nuts (I've been procrastiniating installing it for months now), changed oil and filter, changed transmission filter/seal and fluid and installed new ignition coils for $750.
I bought a oil catch can from eBay and going to install it this weekend. Expect more pictures from my adventure....
Old Jun 3, 2017 | 10:26 PM
  #4056
MacRoadie's Avatar
Changed tranny fluid and filter, and transfer case oil. Transfer case is a PITA. Fill plug is blocked by parking brake cable and you can't get a straight shot at it due to brake drum.
Anyway, pretty sure the t-case had never been drained based on that plug location, the fact that it was in there pretty tight, and bone dry when it came out. Also just a guess, but I'd wager no more than a quart or so came out, but over 2 went back in.
Old Jun 4, 2017 | 01:56 AM
  #4057
MrValingo's Avatar
P0455. Gas cap wasn't on all the way....was it really that easy??
Old Jun 4, 2017 | 06:32 PM
  #4058
I have had mixed results rebuilding stuff, but I did rebuild my ABS Pump and that has worked out incredibly well.
I got my pump from Napa, and it had a limited lifetime warranty so they replaced it. Loved that.
My steering has been stiffish, and odd for years. I think the Steering box has been going, and blowing the pumps. I have one on order and am hoping that fixes for a while anyway.
Old Jun 5, 2017 | 12:56 AM
  #4059
MrValingo's Avatar
Clock is now led backlit. Bypassed the shuttle valve wiring. Cleaned the in-dash cup holder that's been sticking since I got the truck.
Old Jun 5, 2017 | 05:02 AM
  #4060
zoltan7's Avatar
Managed to successfully plated the rear frame and welded the broken bracket of my rear panhard bar back on to the frame.
Somehow must've arc'ed electricity or had a bad ground point lol because I fried both stainless extended lines in the rear I guess I can only hope I didn't smoke the ABS lines as well.
Woe is me lol
