Old Mar 26, 2018 | 05:11 AM
  #5051
JUKE179r's Avatar
Yes Sir... getting spares. Just in case.
Old Mar 26, 2018 | 06:39 PM
  #5052
Psycho_Taco's Avatar
I replaced the o-rings on each injector to fix lean codes that stayed around after the HG job. The disco idles so much smoother now. It went from being angry and rocking mildly side-to-side to running almost as quietly as the V6 in my camry!
Old Mar 26, 2018 | 07:36 PM
  #5053
Richard Gallant's Avatar
Dropped my 04 off for slider build and fitting. Get it back tomorrow, final mounting next week after powder coating.
Old Mar 27, 2018 | 07:47 AM
  #5054
redrover75's Avatar
Default Cps
I saw that cheap CPS and was wondering if someone would report on it. Why would you buy two?
Old Mar 27, 2018 | 10:03 AM
  #5055
Saturnine's Avatar
Replacing the radiator, WP and fan today. It snowed last night, should be fun
Old Mar 29, 2018 | 01:01 AM
  #5056
Gripen's Avatar
Replaced the shocks and steering damper with Terrafirma units. Replaced the rotoflex. Truck is still on jack stands for more work tomorrow.
Old Mar 29, 2018 | 10:29 AM
  #5057
Saturnine's Avatar
Ordered HG kit
Old Mar 29, 2018 | 11:21 AM
  #5058
Jeff Blake's Avatar
Originally Posted by Saturnine
Ordered HG kit
I'd swap the gaskets out for Elring: https://www.turnerengineering.co.uk/...et-c2x20634424
Blower motor is making a racket on high speed after cleaning the cage, pulled it again and found the outer ring on the squirrel cage split, causing the cage to make contact with the housing at high speed. Put in some plastic weld and super glue, hoping that will fix it.
Debating on removing the last rear left passenger seat. I know I'll regret it 1-2 times a year, but it could really open up a lot of space, and reduce weight.
Old Mar 29, 2018 | 01:04 PM
  #5059
Alex_M's Avatar
Fixed my oil leak! Knock on wood.
Turns out the plug on the side of the front cover just above the oil filter had somehow loostened up. I cranked down on her and sure enough, leak is cured. Wish I knew how that plug had come loose. Pretty odd. Oh well, no sense questioning simple fixes. They don't come along often.
Old Mar 29, 2018 | 05:29 PM
  #5060
CollieRover's Avatar
I had converted to DI blades, but one was bent at a car wash. I ordered the kit from Atlantic British and they are great. I had been using extra spring clip deals to get pressure. I had no ideas the springs on wiper arms worn out, I guess that makes sense.
if you have not done this, do it ASAP!
