Old 06-28-2017, 01:22 PM
Davis31052's Avatar
this past Sunday and Monday I installed new coolant hoses thru out in conjunction with a repaired bleed nipple on radiator. New water pump and crank seal while I was there. Found a few bolts missing and a leaky water pipe o-ring behind the alternator.
3 drain and refills on transmission with a new filter on final refill.
Transmission shifts much firmer now.
Still have two dead O2 sensors even though I replaced all four. Assuming I have a faulty ground on the two DOA's. Anyone know what color the ground wires are so that I can test that?
A/C condenser fan on order and fixing the A/C is next on the list.
  #4162
Old 06-29-2017, 09:41 AM
mln01's Avatar
You might also try bench-testing the "dead" O2s to help the diagnosis.
Based on my read of the electrical diagrams and RAVE the O2 ground wires are red with a black stripe.
  #4163
Old 06-30-2017, 10:52 PM
MacRoadie's Avatar
Default New Armor
New steering guard and front and rear diff guards.
  #4164
Old 07-01-2017, 05:51 AM
Davis31052's Avatar
Info on the steering guard please?
  #4165
Old 07-01-2017, 09:18 AM
MacRoadie's Avatar
For those asking:
It is a BRITPART model DA2249. At LR Direct https://www.lrdirect.com/
https://www.lrdirect.com/DA2249-Disc...keep_https=yes
$75.50 US plus $56.00 two day shipping to California.
  #4166
Old 07-01-2017, 09:53 AM
Luckyjayb's Avatar
Nice. Will have to look into them. I dropped my headliner off at the shop today and having it recovered in black instead of tan. If anybody is in the bham area, they are located in Pelham and it's only $280 for the standard d2 headliner with dual sunroofs and standard colors. I can give the number if anybody is interested.
CollieRover (07-02-2017)
  #4167
Old 07-01-2017, 11:20 AM
Jeff Blake's Avatar
Originally Posted by MacRoadie
For those asking:
Can you post a photo from the front of the truck, looking straight at the car? I'd also like to see a shot of the terrafirma one. Can't decide if I want one. I like the 'naked' look from the front.
  #4168
Old 07-01-2017, 12:19 PM
MacRoadie's Avatar
  #4169
Old 07-01-2017, 01:48 PM
Twix's Avatar
Working on putting my extended brake lines in. Are the longer lines for the front?
  #4170
Old 07-01-2017, 07:09 PM
MacRoadie's Avatar
Default Sway Bar Disconnects
Front disconnects installed. Rears next.
Need to figure out how I'm going to install the strap on the driver's side still. Frame hole I used on passenger side is in use on driver's side. Can't just attach it to the plastic dust shield as the straps support the sway bar and hold it out of the way when disconnected.
Quick Reply: What did you do with your DII today?
