Old May 28, 2018 | 03:15 PM
  #5391
Best4x4's Avatar
Normally for a MAF swap you're "supposed" to clear the adaptive settings. Then the D2 will learn and adapt to the new MAF. Is it 100% always required nope especially when slapping in a Bosch for Bosch, but if your D2 had an MAF that was so messed up it learned it's readings, when you'd install a replacement it would be trying to run it with the old bad MAF's setup.
I personally have always just used Bosch units I've grabbed from junk yards for 5.00 each (without the housing). I've only had one INOP one and I just took it back and swapped it out for another one.
Old May 28, 2018 | 05:34 PM
  #5392
Twix's Avatar
It was reset, for whatever reason, it was reading more air than what was actually passing through it.
Old May 28, 2018 | 09:39 PM
  #5393
Saturnine's Avatar
I have a feeling this has probably been discussed before but can you just grab any ol' Bosch maf element from lets say.. and Audi / VW? Obviously the housings are going to be different diameter etc but the element could be the same?
Old May 28, 2018 | 09:46 PM
  #5394
Best4x4's Avatar
Bosch has a few MAF's with the same mount as the D2 so you'd have to be careful. If the sensor itself has the same P/N then sure it should be the same. I had an MAF that ran a bit funky at idle but otherwise no check engine lights were and and I cross referenced it from a 7 series BMW. It came in the D2 when I bought it, but I swapped it out for a spare I had.
Old May 29, 2018 | 01:51 PM
  #5395
Disco_Dion17's Avatar
Bought a GROM-BT3 bluetooth adapter and swapped it in for my CD changer which was no good. Replacement was as easy as pulling the radio and swapping the blue plug with the GROM unit plug. Only tough part was finding space for the box behind the radio (especially with my big hands). Ran the wire for the microphone down under the steering column and up the left side of the dash. Mounted it on the top of the dash between the instrument cluster and radio. Now when the radio is in CD mode, it operated the bluetooth.
Sound quality is flawless and you can control the phone using the skip functions on the steering wheel.
Answer call = skip forward
Decline/end call = skip backwards
Completely worth the $140. Cheapest from the GROM site directly and you can use the promo BT35OFF to get $5 off your purchase. Also need radio pulling keys ($10 on Atlantic British).
Old May 30, 2018 | 06:45 AM
  #5396
ThisRoverGuy's Avatar
For what it’s worth, there are YouTube videos of how you can pull the radio without the “keys.” But I only got it to work a few times. I ended up buying the keys because they make the job dead simple. So, while they’re technically optional, I say spring for them (I think I bought mine on eBay for $5).
If I recall correctly, the first time I pulled mine it took a lot of pressure. Likely because it hadn’t moved in 11 years. If you have the keys, you can pull with less worry that you’re breaking something. If you do the YouTube hack and are pulling hard, it makes you think maybe you’re doing it wrong.
Old May 30, 2018 | 09:39 AM
  #5397
I did see some of those youtube tutorials on how to do it. I was afraid of the same thing; I don't think the radio in mine had moved since it was installed in '99. The keys made it easy as hell and I didn't have to worry about breaking the face off it. I should've dug a little deeper to find them on ebay it sounds like!
Old May 30, 2018 | 11:42 AM
  #5398
The Deputy's Avatar
Been listening to a whining noise, since drowning my rover last fall. Thought it was the alternator, that actually seemed to be getting quieter over the last few days. But, this morning...found out I was wrong.
Idler pulley let loose a mile from work and just barely made it...before temps spiked. Replaced belt and idler pulley, filled with anti-freeze...test drove at lunch...fifteen miles...so far...so good...quiet as a mouse now.
Brian.
Old May 30, 2018 | 11:57 AM
  #5399
Brian.
When was the whining occuring? I drowned my truck too about a month ago and I now have a whining when I press on the accelerator, disappears when I let off, then comes back again as I coast. Gets louder with speed. Any chance this was your experience?
Old May 30, 2018 | 12:54 PM
  #5400
The Deputy's Avatar
Yes, slightly louder with acceleration and diminished when slowing down. Just remove your belt and spin each pulley. Yes, I'm good at giving advice...but not following it myself...lol.
Brian.
