Old May 4, 2018 | 03:20 PM
  #5291
Fastercat's Avatar
Originally Posted by Best4x4
Some people say adios to the interlock completely, but I’ve seen the aftermath when a passengers handbag snags the handle and it goes from 4Hi to N then in the panic that follows someone bumps it either back into 4Hi crank snapple pop, god forbid into 4Lo when a rather larger jolt is felt followed by a lovely explosion of internal parts & outer casing. On a strictly off road truck okay maybe, but on a LR used on the highway I’d just get an 03 linkage (if you don’t have a CDL) or an 04 linkage and fix it properly by bypassing removing the inop unit from the TC, and using the newer external stye found on 03 or 04 linkages. Might be a few $$$, but it’s way better vs what “could” happen.
i asked Before and the replies I got were to remove it. I’ve added the Ashcroft cdl. I’m not sure if the 04 solenoid system is compatible? I usually keep my wallet and gloves in between the transfer case shifter and dash. Hopefully that’s enough of a lockout. One of my parts trucks has an operable solenoid, maybe I can pull that one when I get a chance
Old May 4, 2018 | 05:01 PM
  #5292
Best4x4's Avatar
Only the OEM LR 03-04 has the interlock mount on the shifter itself. 99-02 is like a D1 and is located on the TC itself. The actual solenoid itself is the same part I’m like 99% sure so you could slap in an interlock solenoid from any 94-04 D2 into the TC.
“If” it pops out into N just don’t panic. Coast to a stop, put trans in N and then pop it back into 4Hi.
04 D2 only has one interlock solenoid. If it’s hard to move (but does move) it’s the linkage is corroded vs the interlock.
Old May 4, 2018 | 09:11 PM
  #5293
JoJo The Giraffe's Avatar
Do you plug the from unit at the back of the radio/cassette unit, or do you connect at the cable connection where the cd changer used to be?
Old May 4, 2018 | 10:49 PM
  #5294
Jeff Blake's Avatar
Grom? Connects at the head unit
Old May 4, 2018 | 11:07 PM
  #5295
Sounds too damn easy. I will have to look into that. Thanks.
Old May 5, 2018 | 07:44 PM
  #5296
Jeff Blake's Avatar
Coil relocation! Easy peasy, lemon squeezyy
Just have spark plugs to go. Didn't have to buy anything, just used scrap stuff I had laying around. Not as pro as Gerry's, but she should get the job done
Old May 5, 2018 | 08:27 PM
  #5297
Saturnine's Avatar
Nice work!
Did you have to get longer plug wires or did they reach?
Old May 5, 2018 | 08:37 PM
  #5298
Jeff Blake's Avatar
Originally Posted by Saturnine
Nice work!
I don't know yet. I'll find out tomorrow
Old May 6, 2018 | 02:57 PM
  #5299
Jeff Blake's Avatar
Wires plugged in and she runs good. Had to cannibalize a spare set of wires
Old May 6, 2018 | 03:18 PM
  #5300
No Doubt's Avatar
Yeah, Baby!
