Old 07-17-2018 | 11:16 PM
TaylorCadence's Avatar
Took a few months to get around to it but they're finally in. FloFlex watts link and outer arm bushings. To tell you the truth, if I were to do them again I'd go with another brand of better quality... The fitment is weird especially on the outer arms- they're too wide which made putting them back into the bracket a real b*tch. Maybe it was a bad batch but greased em up good and with meticulous back and forth prying, the bolts slaved in.
The Deputy (07-18-2018)
  #5642
Old 07-18-2018 | 08:25 AM
Disco_Dion17's Avatar
Been a while since I posted. So here we go...
Put in a new rear diff on the disco (Roverlandparts.com for about ~$350). Had some slop in there that I tried to quiet with heavier (85w-140) oils but in the end it needed to be swapped. Still having some coolant loss issues. Investigating and probably replacing the radiator is next. I think there is a leak in the main body of the radiator (small but its there). Should I replace the t-stat while I am in there? I have heard stories about them not working out of the box and my current one seems to be working fine... should I risk it?
Also going to look into heat wrapping my exhaust on either side of the front drive shaft. Hoping that might reduce the speed of grease drying in the joints. Anyone had success with this?
  #5643
Old 07-18-2018 | 08:54 AM
The_OGCJR's Avatar
I’d replace it and go inline
  #5644
Old 07-18-2018 | 09:06 AM
Sixpack577's Avatar
Don't wrap the exhaust, it puts the heat that normally radiates off of it, through it, and through the catalytic converters...and they can't handle it.
A member here recently wrapped his exhaust manifolds, and it made the cats too hot.
  #5645
Old 07-18-2018 | 09:12 AM
wjsj69's Avatar
I just got the same kit. Thx for the warning. Maybe it's better to be tight so your axle isn't flopping around back there..
  #5646
Old 07-18-2018 | 12:39 PM
Lmk how yours turn out. Tight good yes, but you got to be weary of the sleeves in the middle of the bushings. If you torque the bolts too tight (LR specifications) it will obliiterate them. I went with a quarter of the specification and they feel nice and snug.
Thats another thing is that FloFlex includes some jibberish one-liner instructions on how to torque pressing the “outer lip home?” No regard to using silicone grease either. Like with anything, had to do a lot of research on getting it as right as possible with little info or guidance on the internet with poly bushes.
  #5647
Old 07-18-2018 | 03:38 PM
Bulax99's Avatar
Restitched the steering wheel!
Sixpack577 (07-18-2018)
  #5648
Old 07-18-2018 | 06:17 PM
The_OGCJR's Avatar
Not if its after the cat though.
  #5649
Old 07-18-2018 | 06:24 PM
No Doubt's Avatar
My daughter's "Randy" got to meet her first 4x4, Spunky, today and do some 4x4ing.
After driving both vehicles, I can confirm that the old CJ-5 is a hip-displacing back-buster compared to the easy-going Disco 2 off road.
  #5650
Old 07-18-2018 | 08:33 PM
Twix's Avatar
Detailed the interior best I could for an 18 year old truck. Getting her ready for a European Auto Show on Saturday here in Calgary
Quick Reply: What did you do with your DII today?
