Old Feb 18, 2020 | 01:48 AM
  #7211
Stephen Perez's Avatar
Default I’ve done a lot with my ‘99 disco...
Fellow Rovers,
it’s been almost a year since I’ve posted. I got back home and walked into my garage thinking “I have no idea where I left off” over the past 2 weeks I made my ‘99’s short engine to a 4.6 (I’ll post a conversion thread sometime with a lot of photos)
Now for today... I installed my front cover and water pump onto my short block. I put my new harmonic balancer ($500 :’( ) on and I’m trying to figure out how to torque that down to specs.
I then installed my headers/exhaust manifold assembly onto my short block. I placed my new lifters and pushrods in followed by the rockers and got the valley gasket on. Topping it off I placed the valve (rocker) covers on and I left off searching all over my garage for my injector clasps and the dowel for the driver side rocker cover. It was an eventful long weekend.
-Stephen
Old Feb 18, 2020 | 06:56 AM
  #7212
Sixpack577's Avatar
Put a piece of wood between the crank and the engine block to torque the crank pulley, 200' lbs.
You'll also have a much easier time putting the engine in and bolting on the motor mounts Without the exhaust manifolds on.
Old Feb 18, 2020 | 11:26 AM
  #7213
T-rex's Avatar
Originally Posted by mln01
Pics?
Dirty and a little rust, but they should clean up nicely. They were held on with only three "bolts" right in the middle of each side. Screwdriver type heads and way too small for the application. It's a wonder they didn't just fall off the donor truck on a highway somewhere and kill somebody!
Old Feb 18, 2020 | 12:23 PM
  #7214
DaBehrsD2's Avatar
Great find!
Old Feb 18, 2020 | 05:21 PM
  #7215
Flyin4AWA's Avatar
Default Oxygen Sensor Fault Hunt
Today I spent tracking down why my downstream O2 Sensor heaters weren’t working on Bank 1 and 2. They were new yesterday, but still threw a code. So, I discovered they are wired in series, and if one is cut or shorted, neither will work. The culprit was a hungry packrat who gnawed on the “blue wire” on top of the transmission. So when those two downstream stop heating, you now know where to look. Codes gone, life is good!
Old Feb 18, 2020 | 08:45 PM
  #7216
Fastercat's Avatar
Originally Posted by wjsj69
Yo Al, W.T.F. is that, at bottom right?? Please tell me it's a BabyRuth.
lmaof
Old Feb 19, 2020 | 08:07 AM
  #7217
The_OGCJR's Avatar
odd that they don’t have a C channel
Old Feb 19, 2020 | 07:01 PM
  #7218
The Deputy's Avatar
Default Wife's 03
Replaced radiator and thermostat, disassembled heater blower motor and lubed bushings, replaced blown steel brake line - to left rear - and rubber hose and bled system, washed, cleaned windows, checked air in tires and filled up with fuel.
Brian.
Old Feb 20, 2020 | 12:33 AM
  #7219
DaBehrsD2's Avatar
Originally Posted by Boostle
Installed a rear view mirror with integrated reverse camera from amazon. Not sure how i've lived without one on this vehicle for so long!
Also interested in which one and your thoughts.
Old Feb 20, 2020 | 04:17 PM
  #7220
No Doubt's Avatar
Talking
Originally Posted by No Doubt
My daughter stuck her new Jeep 4x4 in the mud while off-roading today so I towed her out with my Disco on my old, no-tread tires.
My new mud tires won't arrive until Thursday. Would have felt more confident going deep in the mud to get her if I had new mud tires instead of the old, no-tread street tires, but it all worked out.
Installed some fantastic 265x60 R18 mud tires. Much needed!
Just $121 at Walmart for these Achilles Desert Hawks.
