Old Mar 8, 2020 | 04:14 AM
  #7281
DCDisco2's Avatar
I did Best4x4s PCV mod and replaced the rotted out airbox inlet hose on my 04 with a Carrs4x4 rubber hose. End result is a much quieter idle and what seems just a generally smoother engine performance.
Tomorrow I’m replacing the SAI filter with a K&N reusable filter ala JUKE179r. Just trying to keep her healthy and happy as long as possible!
edit: did the SAI, probably cut initial rocket ship noise in half. Great mod, I used my Dremel to grind off the post next to the air inlet tube to let the filter slip on
Old Mar 8, 2020 | 02:01 PM
  #7282
PanicAtTheDisco's Avatar
7th Gear
Joined this forum. Idk if that counts?
Old Mar 8, 2020 | 02:34 PM
  #7283
No Doubt's Avatar
Talking
Great screen name!
Old Mar 8, 2020 | 11:49 PM
  #7284
Richard Gallant's Avatar
Added a overflow catch bottle - temporary addition. I am going to obsess about coolant until I get the cooling system stabilized again.
Just making sure I do not have any more over pressure issues
  • Clear Glass bottle
  • Some fuel line
  • Hose clamp
Any coolant loss via the the overflow line will hit the bottle, enough loss will exit via the top in to the jack container then out via the drain holes.
I can examine the bottle after driving to make sure it is dry, I am not expecting any issues but I want to know.
Old Mar 9, 2020 | 11:24 AM
  #7285
NewToTheTwo's Avatar
So after 220k miles, brake job and fluid flush, BOTH of my front brake hoses started leaking.
No idea why, but figured it was time to replace.
Stainless Steel lines front and rear and more flushing just because.
Used the ABS pump solenoid trick to flush then had my wife finish it off with pumping the brakes.
JB Kwik Weld on a very slow coolant overflow leak - one of the inner ribs/seams on the bottom was seaping - very slow - so far so good with the JB weld.
Old Mar 9, 2020 | 02:13 PM
  #7286
Davis31052's Avatar
Care to share in detail how you used the ABS pump to bleed your system? I ask since I am doing all brake lines this year as well. I've seen it mentioned here many times, but no one has ever done a sticky about it.
TIA, Eddie
Old Mar 9, 2020 | 02:23 PM
  #7287
TIA, Eddie
I used about 20' or so of speaker cable for the wire since its what I had - spade connectors on one end and a button on the other.
I think I got my button from Lowes, Any on/off switch or button will do.
Key/ignition does NOT have to be on.
Remove ABS pump solenoid (RELAY is the right term) from engine bay fuse box and insert spade connectors as seen in the pic.
In normal brake bleed sequence, push the button to turn on the pump, crack the bleed screw open - bleed/flush - close bleed screw, turn off pump.
Move to the next wheel.......
Old Mar 10, 2020 | 04:49 AM
  #7288
JUKE179r's Avatar
@NewToTheTwo Spot on description!
Old Mar 11, 2020 | 01:02 PM
  #7289
Davis31052's Avatar
Copy that! Thanks!
Old Mar 15, 2020 | 01:57 PM
  #7290
GreenKnight008's Avatar
6th Gear
My wife got sideswiped by an uninsured driver at the end of January, so new steel rear bumper, some body work, and a few new trim pieces are slated for install. Washed the Disco yesterday and installed the new Genuine tail lamp covers I picked up with the other parts. Was able to get the parts for the body shop at about $400 less than they quoted using Atlantic British and not going with the stock rear bumper that got torn up on the driver's side. This will also give me a chance to have the body shop touch up some paint imperfections on the hood and a minor scrape from a couple years back. Unfortunately I've got another three weeks to wait to get it into the shop. Planning to get an alignment done on it before then since the damage is centered around the driver's rear quarter/rear wheel.
