#7381
#7383
The oil pan is very strong...but it's cast aluminum.
Keep applying weight and pressure to it, see how much it takes to crack or break it...and have the jack punch through, crush the pickup tube, and the engine fall back on to the mounts.
And hope your hands/arms aren't in the way when it does.
JUKE179r (04-17-2020)
#7388
The following 5 users liked this post by whowa004:
DiscoID (04-20-2020),
JUKE179r (04-17-2020),
No Doubt (04-17-2020),
Richard Gallant (04-17-2020),
The_OGCJR (04-18-2020)
#7389
#7390
Not a story, I have personally seen it, not on a D2, but on a gm smallblock. Metal pan buckled under the weight and crushed the pan and pickup.
Fortunately no one's hands were in the way.
Yes, the D2 pan IS heavy duty...but cast aluminum is known to be brittle. It has very little give before it cracks.
Especially if there is a flaw, trash or air trapped in the material, then you have an unseen weak spot.
Do as you will, but jacking on an oil pan is not smart.
Jacking on the crank pulley is much safer, can support Alot more weight than a pan, Alot more, and usually is an easier spot to get the jack under.
