Finally got my windshield cowl and installed it. Replaced the washers on the wiper arm attachment with stainless steel washers (5/8"). Clips from the old one to secure the foam filter, so hopefully it doesn't get pushed out anymore.
Besides I did my 30k miles service: diffs, TC, transmission fluid changes.
Originally Posted by ace10
I'm doing mine right now. Pulled the hood off so I can do blackout vinyl at the same time.
I didn't have a plan for the big metal washers. The exposed side had quite the "patina." Got lucky as the underside still had a nice coat of black paint. If I wasn't already in the job, I'd go with the stainless washers, for sure.
Did either of you guys do the D1 wipers conversion also?
When I took my D2 for its first VA state safety inspection last week, I got bounced for bad wipers. Stupid me forgot to install the newly-purchased blades.
My ext temp is in C and Im pretty sure it goes below -20. I think-18 is about 0F. I could have confirmed yesterday but it’s warmed up to 16C this morning. My P38 read -24C yesterday but It’s not the same vehicle.
Replaced all interior, and rear lights, with Sylvania Zevo LED bulbs.
Turn signal and fog lights were 1156 Amber. Note, Amazon says these do not fit but they do. Turn signal does require a load equalizer. I used the Sylvania one.
Brake lights were 1156 Red, and backup 1156 white.
Finished the windshield cowl. Even replaced the side gutter thingies and the pop in screws.
Buttoned up the refresh on the rear.
New door handle gasket. License plate bracket. LED license plate lights. Mounted the new spare setup. 245/75. Clears the bumper by maybe an 1/8"
Noticed my left side brake/driving light is burned out.
Reattached the hood and applied the blackout vinyl.
Wasn't thrilled with the vinyl. Neither my work nor the product. Bought it from Lucky8. The shape isn't precisely correct. It's too wide at the aft end to allow it to fit all the way forward. And, really, there's zero reason to not have the template cut to fit the trailing edge of the hood. Nobody is going to wrap it under, unless they're a pro.. My trim cut sucked. Such a bummer.
same here. temp was -2 and the display read 0. do you have yours set for Fahrenheit or Celsius? mine is still Celsius, as i didn't change it back after the last time i had the battery disconnected.
125k miles on my drive to work. To be fair, I've only put about 1,736 of them on myself since buying the truck in April '22.
Also installed a new battery (walmart Duramaxx 65 850 CCA) and she's running great! BTW, I found it interesting that my radio station presets were all still there after having battery out for a few hours. But the clock had reset and the AC display changed from F to C, although the preset temp was the same.
