What do I need to fix here - Water Pump?
Old Feb 15, 2019 | 10:53 AM
  #21
DISCOFETA's Avatar
Was just looking at your first post again and in this picture it appears to be leaking from the water pump gasket.
And yes, in the other picters you took, if it was leaking out of the weep hole...you'd have seen stains. I'd just order a new water pump and gasket and take care of it before it becomes a bigger issue.
Brian.
Thank you. If I order from Atlantic British the pump, gasket, and bolt set what else should I change while I have it off? I was thinking my belt. Someone said fan clutch, is that necessary?
Old Feb 15, 2019 | 11:06 AM
  #22
DISCOFETA's Avatar
Originally Posted by shanechevelle
I wouldnt waste money adding any when you're going to wind up swapping coolant.
drain that trash out, flush it, and add green at your earliest convienence.
So you say flush and green.
Atlantic British says the special Land Rover only coolant
Some say Dexcool only (which I dont know where to buy)
​​​​@Disco Mike said Peak Global Lifetime
Which is best for my 2001 disco 2?
Old Feb 15, 2019 | 12:14 PM
  #23
Best4x4's Avatar
Green is common & now it last over 100k. AB recommends a lot of things that I personally avoid. They want you to keep buying stuff from them lol.
Old Feb 16, 2019 | 04:57 AM
  #24
shanechevelle's Avatar
I've been running green for about 6 years and I dont have any issues.
dexcool did have a class action lawsuit.
Old Feb 18, 2019 | 06:08 PM
  #25
Daytoman's Avatar
Is there a couple fo different options for a new water pump? One has a better flow? Which one is the consensus best? Airtex?
Old Feb 18, 2019 | 06:25 PM
  #26
Best4x4's Avatar
Brass impeller is the best, but honestly if your coolant is in good condition the 33.00 water pump will do just fine. You won't see any performance pumps. You'd only see different results if you played with the pulley size. OEM water pump does a good job.
Old Feb 18, 2019 | 06:46 PM
  #27
Go green.
Old Feb 19, 2019 | 06:49 AM
  #28
DISCOFETA's Avatar
Cost aside, what would perform better, Green or Peak Global Lifetime?
Old Feb 19, 2019 | 04:29 PM
  #29
Richard Gallant's Avatar
There is generally speaking no real difference - BUT it has to be aluminum engine safe. That should not really be an issue any more but it never hurts to check.
Old Feb 21, 2019 | 07:41 AM
  #30
DISCOFETA's Avatar
What is the recommended torque for the bolts around the water pump?
