What to do to replace valve cover gaskets?
Old Oct 30, 2009 | 01:47 AM
rod76's Avatar
8th Gear
Default What to do to replace valve cover gaskets?
Hi everybody, I`m new on this; I never before worked in an engine, thats why need help because my D2 had oil leaking problems and some mechanic told me its from the valve cover gaskets (left side).
Can someboby told me if it is a job easy to do?
Thanks....
Rod
Old Oct 30, 2009 | 04:37 AM
Rod-go to Sears and buy a 12 point 8mm socket in 1/4" drive.
Then you will also need a 1/4" drive rachet and 6" extention.
Tighten the bolts on the valve cover, both sides of the engine, the leak will stop.
This happens to EVERY Land Rover and it is recommended that you tighten those bolts every oil change to prevent leaks.
Just snug them up good, dont reaf on them, just good and snug.
Old Oct 30, 2009 | 11:12 AM
rod76's Avatar
8th Gear
Thank you Spike:
I'm goin to tight the bolts on the valve cover, but I have a question, (it maybe could sound stupid); the bolts situaded outside of the valve cover are easy to reach, but what happen with the inside bolts, how can I reach to tight them?
Thanks again.
Rod76
Old Oct 30, 2009 | 11:22 AM
sloppyjoe's Avatar
what inside bolts? under the cover?
Old Oct 30, 2009 | 11:36 AM
NiteTrain's Avatar
Originally Posted by rod76
Thank you Spike:
Rod76
you don't wanna know....you have to remove the damn intake..worst design ever
Old Oct 30, 2009 | 11:49 AM
rod76's Avatar
8th Gear
Thanks nitetrain, I'm imagine need to do that...
Old Oct 30, 2009 | 01:11 PM
Suede's Avatar
If I wasn't the orginal owner of the vehicle, then I'd remove the valve cover completely. There are little metal spacers on each bolt hole, and it's VERY easy for them to fall away upon valve cover reinstallation. If any of those are missing (especially the ones at the rear) then simply tightening the bolts won't do the trick (could actually make the leaking worse).
So I'd remove the cover, inspect the gasket, remove any debris around the edges, make sure one of those little spacers didn't pop out and is sitting in a drain hole in the head, then carefully reinstall. While you're at it, do a simple valve clearance adjustment.
Old Oct 30, 2009 | 02:10 PM
Spot's Avatar
Thanks spike, I have the same problem with mine. Now I don't have to waste a thread!!
Old Oct 30, 2009 | 04:43 PM
Thank you Spike:
Thanks again.
Rod76
Dont worry about those ones, oil wont leak from the "top" of the valve cover, you know, gravity and all.
The "bottom" side is the side that leaks because the oil pools on the low side and then seeps out.
Snug up the bolts you can reach and fagetaboutit!
Good man, good man.
RROJ
Mar 26, 2011 02:37 PM
dieselgeek
Jan 18, 2009 09:30 PM
04BluDisco
Jan 2, 2009 02:38 PM
brw1982
Jul 21, 2008 11:42 AM
herblatham
Jun 25, 2008 09:50 AM
