what's the belt that makes noise when i turn on A/C
Old Aug 9, 2007 | 01:33 PM
mimimi's Avatar
Default what's the belt that makes noise when i turn on A/C
i noticed belt noise came on when i turn on A/C, and disappeared after i turn off A/C, is it the alternator belt?
Old Aug 9, 2007 | 01:46 PM
98roverguy's Avatar
Default RE: what's the belt that makes noise when i turn on A/C
Sounds like you need a new belt tensioner. I'd replace the belt with it and also check the other pulleys for bearing wear.
Old Aug 9, 2007 | 02:02 PM
mimimi's Avatar
thanks 98roverguy
do you mean alternator belt tensioner or any other belt tensioner?
Old Aug 9, 2007 | 02:10 PM
First of all, what year is your truck?
Have you looked to see what your engine has for a belt?
Mike
Old Aug 9, 2007 | 05:52 PM
mimimi's Avatar
2003 disco II S
78000km
Old Aug 9, 2007 | 05:58 PM
98roverguy's Avatar
You stated your mileage in km so I'm assuming your in Europe/England and have a diesel Tdi?
Old Aug 9, 2007 | 07:56 PM
So, all D2's have 1 serpentine belt that deives everything. Not knowing how long it has been since you changed them out, I would suggest a belt, a belt tensioner and a idler pulley.
Also, I would suggest you get in under the hood and become more familiar with your truck, if you ever really have a problem or break down you will wish you knew more about what you drive.
Good luck,
Mike
jdwilks
Jul 24, 2014 09:09 AM
Miwo
Mar 16, 2011 02:01 PM
DeepBlueWater
Sep 27, 2007 07:39 PM
andrewcloy
Sep 10, 2007 08:27 AM
