what is going on
Old Dec 4, 2008 | 09:54 PM
donzisoucie's Avatar
4th Gear
Default what is going on
Love this disco but man it is a tempermental b. Here is my new problem for this disco II. She starts up great and runs nice for until she gets warm then she starts sputtering at cruise speed, but when i give her some gas she wakes up and then sputters again at cruising speed. I am hoping a fuel filter or pump? I am not going to the dealership they will probably try to sell me a new gas tank....... Any info would be great this forum rocks.
Old Dec 4, 2008 | 10:01 PM
hazletbassist89's Avatar
Default RE: what is going on
That definitely sounds like a fuel delivery problem. First off what year, how many miles and has it thrown any codes? Any lights on the dash?
Old Dec 4, 2008 | 10:16 PM
sloppyjoe's Avatar
how often do the TB sensors get funky on these rigs?
Old Dec 4, 2008 | 10:18 PM
4th Gear
It is a 2000 and i just had the whole engine ran through spark plugs, fluids, hoses. I have not had any codes run on it yet and there are no lights on the dash
Old Dec 4, 2008 | 10:24 PM
sloppyjoe's Avatar
based on the info and my experience on past vehicles,
it sounds like a fuel issue. either a clogged filter or a pump going. my money is on the pump.
Old Dec 4, 2008 | 10:33 PM
4th Gear
I hope your right that sounds fairly inexpensive any experience installing one on a disco.
Old Dec 4, 2008 | 11:03 PM
sloppyjoe's Avatar
last pump i changed was on my dads truck. required lifting the bed from the frame.
but if i am betting you can gain access to the pump from under the rear cargo area. under the cargo mat.
give it a lift and check it out.
Old Dec 5, 2008 | 01:29 AM
Disco2Guy's Avatar
Sorry I don't have the pics from the RAVE but...
Pump - fuel
19.45.08
NOTE: The fuel pump and fuel gauge tank unit are
integral parts of the fuel pump housing and cannot be
renewed separately
Remove
1. Release fixings and remove battery cover.
2. Disconnect battery earth lead.
3. Models with third row seats: Remove RH
third row seat.
+SEATS, REPAIRS, Seat - third row.
4. Remove 5 trim clips securing lower edge of RH
'D' post trim casing.
5. Models with rear ICE controls: Remove
screw securing remote ICE controls to RH side
trim casing.
6. Models with rear ICE controls: Release ICE
controls from RH side trim casing. Disconnect
multiplug and remove ICE controls.
7. Partially remove tail door aperture seal in the
area of the RH side trim casing.
8. Remove 2 trim clips securing RH side trim
casing to body.
9. Remove rear lamp access panel from RH side
trim casing.
10. Remove trim clip securing RH side trim casing
to lower 'E' post.
11. Models with third row seats: Remove bolt
securing lower mounting of third row seat belt to
body.
12. Remove RH side trim casing.
13. Pull back loadspace carpet from fuel pump
access panel.
14. Remove 6 screws securing access panel.
15. Remove access panel.
16. Disconnect multiplug and fuel hose from fuel
pump housing.
CAUTION: Always fit plugs to open
connections to prevent contamination.
17. NAS models: Disconnect pressure sensor
pipe from fuel pump housing.
18. Use LRT-19-009 to remove locking ring from
fuel pump housing.
19. Remove fuel pump housing.
20. Remove and discard sealing ring from fuel
pump housing.
Refit
1. Clean fuel pump housing and mating face on
fuel tank.
2. Fit new seal to mating face on fuel tank.
3. Fit fuel pump housing to fuel tank and use LRT-19-
009 to fit locking ring.
4. Connect multiplug and fuel hose to fuel pump
housing.
5. NAS models: Connect pressure sensor pipe to
fuel pump housing.
6. Fit access panel and secure with screws.
7. Reposition loadspace carpet.
8. Fit RH side trim casing.
9. Models with third row seats: Fit bolt securing
lower mounting of third row seat belt to body
and tighten to 50 Nm (37 lbf.ft).
10. Fit trim clip securing RH side trim casing to
lower 'E' post.
11. Fit rear lamp access panel to RH side trim
casing.
12. Fit trim clips securing RH side trim casing to
body.
13. Fit tail door aperture seal.
14. Models with rear ICE controls: Connect
multiplug to remote ICE controls.
15. Models with rear ICE controls: Fit ICE
controls to RH side trim casing and secure with
screw.
16. Fit trim clips securing lower edge of RH 'D' post
trim casing to body.
17. Models with third row seats: Fit RH third row
seat.
18. Connect battery earth lead.
19. Fit battery cover and secure with fixings.
Old Dec 5, 2008 | 10:03 AM
ORIGINAL: donzisoucie
Do you have any fault codes? It is not a fuel filter, your truck doesn't have one.
How many miles on the engine, did you replace the plug wires also, how about the 02 sensors, have they been replaced, whaty octane gas are you using?
Old Dec 5, 2008 | 10:05 AM
Great post!!!
TATZOO
Jun 10, 2013 05:22 PM
05LandRover
Off Topic
Oct 21, 2005 06:52 PM
jasongilliland
Oct 2, 2005 04:04 AM
jasongilliland
Sep 15, 2005 05:34 PM
bgsats
Audio/Visual Electronics
Feb 8, 2005 02:07 AM
