What the heck demon noise is this?? Video
Old Feb 7, 2020 | 05:21 PM
Brandon318's Avatar
Default What the heck demon noise is this?? Video
Started noticing it really subtle a couple days ago. Then replaced the differential fluid today (https://landroverforums.com/forum/di...d-today-98857/), found all those shavings, and now it's making this terrible noise. Not sure if they're related but ¯\_(ツ)_/¯
86,000 miles FWIW
Old Feb 7, 2020 | 08:07 PM
XRAD's Avatar
brake pads worn out? bad wheel bearing?
Old Feb 7, 2020 | 08:44 PM
Brandon318's Avatar
Stupid question... I always refer to the part you're talking about as wheel bearings, but LR calls them "hubs" right? For the sake of ordering parts...
Old Feb 7, 2020 | 09:03 PM
XRAD's Avatar
yes. Jack it up and spin the wheel. Should not be rough, should turn smoothly..... or drive it slowly around a parking lot and turn the wheel 'stop to stop' and see if the noise comes and goes...
Old Feb 8, 2020 | 04:37 PM
Extinct's Avatar
Were you stopping? What conditions cause the noise?
Old Feb 8, 2020 | 05:20 PM
Brandon318's Avatar
No brakes applied; just driving straight. I think it’s the wheel bearing since the three amigos is also on.
Old Feb 15, 2020 | 03:47 PM
Brandon318's Avatar
Reporting back. It was a toasted front differential.
Old Feb 16, 2020 | 11:39 AM
XRAD's Avatar
good find. Is there a bad hub as well? Sometimes these issues go together.....
Old Feb 17, 2020 | 03:01 PM
Brandon318's Avatar
Yep, both hub bearings were crunchy, but it was the passenger side hub that had some significant play in it. That being said, after replacing the hubs, the noise continued for another day until the front differential grenaded itself. So it was that.
Old Feb 17, 2020 | 03:05 PM
cvhyatt's Avatar
Sounds like you might have a rooster stuck in your fan!
cobbcj7
Oct 29, 2018 01:15 PM
cammyr01
Apr 15, 2015 02:16 PM
nychaze
Aug 22, 2013 02:20 PM
umwolverine
Apr 19, 2013 11:10 AM
MichiganRover
Jan 21, 2013 12:12 PM
