What is this leaking my oil so badly?
Old Aug 7, 2019 | 07:46 AM
05TurboS2K's Avatar
I have this same leak (I think) and it's P/S. I pressure washed the entire area clean, added a few drops of UV dye and ran it for an hour..... it was clearly the P/S connection when I shed a U/V light onto the area with the fresh leak. I'm not sure the dye is great for the system but folks could use this to find the issue and then flush it if they're concerned. Just $.02
OP,
Are you talking about the 2 hard lines running on the drivers side of the oil pan towards the transmission? I had to bend them out of the way to remove my engine just a day ago, I'll confirm them today and reply here if those are what you're speaking about.
-Greg
Old Aug 7, 2019 | 07:49 AM
NewToTheTwo's Avatar
OP,
-Greg
I believe so - I hadnt followed them to the rear - they turn upward in front of the oil pan at the front of the truck and at least one connects to the block with a large 20+mm nut. Its clearly leaking aside from the obvious ps pump leak.
I've cleaned it all since the photos so I know its leaking from this hard line.
Thanks......
MyRoversNameIsCarl
Feb 16, 2017 02:06 AM
DivebombInc
Sep 16, 2011 01:09 PM
ColoradoRover1
Mar 11, 2011 09:57 PM
94svt50
Feb 19, 2011 06:18 PM
tulsa
Nov 7, 2010 08:35 AM
