What lift and driveshaft do I have?
Old Sep 27, 2018 | 12:58 AM
Jason_B's Avatar
Default What lift and driveshaft do I have?
Hi all!
Now that my engine and cooling system seems a bit more sorted. I am moving towards the next most critical components. The driveshaft. I was going to just going to order this one to be safe: https://www.lucky8llc.com/products/front-driveshaft-6 but I noticed it said that if you have more than a 2 inch lift, you need a different one.
I think the previous owner said that it has a 3 inch TF lift. I would like to confirm this and perhaps update either the springs or shocks if needed. I am pot committed at this point, so I would rather have the good stuff as opposed to just getting by.
I am wondering how can I identify if I do have a 3" TF lift or not? Also, should I have matching shocks and springs or what? Please enlighten me on this situation.
Thanks as always!
Also, I started a blog regarding this adventure. It is a bit behind as the most recent post discusses me finding out I need a new engine, but I should be caught up soon: https://maintainingdiscovery.com
Old Sep 27, 2018 | 08:57 AM
wjsj69's Avatar
No real way to find out for sure without a receipt for the parts, or a definitive from the installer. I found an overall height spec; 74.4 inches to the top of the roof. It didn't say where exactly, probably the top of the roof rack. Take a measurement and see how much higher yours is for an estimate.
Old Sep 27, 2018 | 09:56 AM
Dave03S's Avatar
Measure from center of wheel to top of fender arch. report that number here. The RAVE and several threads on here which I don't have time to find list the stock height as well as the height with a 2" lift.
Old Sep 27, 2018 | 01:47 PM
tcr6v1's Avatar
Make sure you have greasable ujoints on your shafts and you'll be fine with a stock shaft.
also make sure the PO installed extended brake lines if you plan on doing moderate off roading. The stock ones are pretty tight with a lift and will rip off if you flex any amount.
Old Sep 27, 2018 | 02:02 PM
Jason_B's Avatar
Great tip about the brake lines, thanks.
LRDISCO
Jul 7, 2021 04:39 PM
satxpipe
Dec 1, 2017 01:45 PM
Manbeer
Jun 8, 2016 06:19 PM
disco1tim
Nov 21, 2013 06:04 PM
Emperor_MA
Jun 15, 2011 11:21 AM
