What machine work to get done to the heads?
Old Jun 5, 2017 | 10:44 PM
tcr6v1's Avatar
Originally Posted by KingKoopa
My machinist did a vacuum test on my heads and the valves sealed so he skipped the 3 angle job, at my request. Runs fine but my vehicle had over 200k on the clock so I anticipated a major engine overhaul within a couple of years anyway. I also did the oil seals myself so I only spent $100 total on head work
how much of a pain was doing the seals yourself?
Old Jun 5, 2017 | 10:56 PM
KingKoopa's Avatar
Not bad at all. Borrowed a valve spring compressor from the parts store, used large vice grips to gently clamp the old seals and spin them off. Then used an appropriately sized socket to tap the new ones on.
Old Jun 5, 2017 | 11:13 PM
Alex_M's Avatar
I did the port and polish on my heads. The polish is probably only a minor help, but the port job definitely wakes her up. Port match to the gaskets on both the heads and the intake manifold.
You have to remember, these heads were designed for a 3.5L engine and they're on a 4.0 or 4.6L, so they're obviously going to be a little bottle necked.
Old Jun 6, 2017 | 07:02 PM
tcr6v1's Avatar
Thanks guy. I'll look into port matching the intake and heads if time allows. I'm placing my order for the timing chain set and water pump now. Anything else? is the oil pump worth it at my mileage (77$) ?
Old Jun 7, 2017 | 02:01 PM
Alex_M's Avatar
Oil pump is worth it every single time you take off the front cover. These engines love to eat oil pumps
Rosslato
May 18, 2023 07:49 AM
kgov
Sep 23, 2016 12:18 AM
Pacerlive
Aug 27, 2011 10:05 AM
JBEGIN
Jun 27, 2009 12:38 PM
