What are my chances
Old Feb 14, 2013 | 04:45 PM
javasteve's Avatar
Default What are my chances
Ok, my head gasket is blown, pretty sure, lots of white smoke, misfire on cyl 2, burning coolant, vehicles runs like dog poop when cold, good when warm. I took it to expedition autoworks in Minneapolis and they will fix it for 3 grand, that includes completely machining the heads so the top end of the engine will be pretty much new. The tech who wrote me up said I could have a shot engine if a sleeve moved. The engine never overheated and there was no coolant in the oil, none that was visible anyway. Good shot my engine is fine and the head gaskets are the only things that are bad, or should I be banking on a shot motor. If the engine is bad what is the cheapest fix?
Old Feb 14, 2013 | 04:47 PM
ZGPhoto's Avatar
The truck never overheated but white smoke was spewing up everywhere?
Old Feb 14, 2013 | 05:03 PM
javasteve's Avatar
just out of the tail pipe when cold, greatly reduced when warm. sorry my head is in the clouds.
Why not pull the heads off and have a pressure test performed on the block to rule out a dropped sleeve?
Also, a normal price for head gaskets is around $1500 plus machine shop for a couple hundred.
Old Feb 14, 2013 | 05:17 PM
Dave03S's Avatar
The top two indy shops in the Pacific Northwest both charge $2400 for head gaskets, with machine work and a valve job included.
Old Feb 14, 2013 | 07:38 PM
javasteve's Avatar
3 large was pretty much the going rate here in MN. Disco they are going to check it before doing the job. Pulling the heads is way above my paygrade, I can do breaks, oil changes, spark plugs etc etc. Head gaskets, not skilled enough. I don't think I dropped a sleeve, one sign is a ticking when the engine is running and that is not happening.
Old Feb 14, 2013 | 09:35 PM
DiscoRover007's Avatar
You probably didn't
Old Feb 15, 2013 | 05:50 AM
drowssap's Avatar
$1500 + or - . by the way head gasket are not above your pay grade, pretty basic once you break it down to steps.
Old Feb 15, 2013 | 06:17 AM
DIY parts kit $300, machine shop $200, 12-15 hours pro labor; or two weekends for a motivated owner with machine shop inbetween.
Old Feb 15, 2013 | 06:20 AM
drowssap's Avatar
$99 craftsman tools set, a 12point 10 mm socket, 24 inch breaker bar and a 5/8 6 point shallow impact socket and a few screw drivers is all that you need
urq
Feb 21, 2012 09:37 PM
03discoman
Dec 5, 2009 03:42 PM
racerboydrew
Nov 13, 2008 08:10 PM
