What Pully is this
Old May 28, 2005 | 03:45 PM
kfordric's Avatar
Default What Pully is this
Anyone know what pully this is i believe tht it is the tensioner but not sure anyone positive i did a screw driver test and the pully's bearings are shot so i want to order a replacement but need to know whether or not its the tensioner. Someone said it may be a "coolant pully" but i never heard of that before. Thanks
[IMG]local://upfiles/424/9A99E88748714183B74E0D4F002DB444.jpg[/IMG]
Old May 28, 2005 | 04:52 PM
Patrick's Avatar
Default RE: What Pully is this
i think that it is the tensioner...
Old May 28, 2005 | 11:49 PM
Bait's Avatar
Default RE: What Pulley is this
Yes, that is the tensioner pulley. The pulley directly below this was the subject of a recall. It should be steel and NOT plastic. It is hard to isolate noises of this type. Have your local LR dealer check for recalls and campaigns. Or PM me your VIN.
Old May 31, 2005 | 03:18 PM
kfordric's Avatar
Bait,
I PM'd you the VIN and I heard that you should not replace the assembly pully, that should be left to the dealer. Is that true? it doesn't look that hard. Is there any specific steps i have to do to replace it? thanks
Old May 31, 2005 | 03:24 PM
mikemeyer0's Avatar
it is the tensioner pully. if you have some mechanic ability it is not a hard job to change, i do belive there is a recall on that one.
Old Jun 4, 2005 | 12:27 AM
Bait's Avatar
kfordric,
I checked your VIN # and there are no open recalls or campaigns on your vehicle. This is usually a good sign that the vehicle has been to a dealer regularly.
It's not hard to replace. I don't think the tensioner pulley is available separate, might have to buy the assembly. To change it easily, you need to remove the viscous fan assembly. This requires special fan wrenches.
Old Jun 4, 2005 | 10:16 AM
kfordric's Avatar
Hey thanks for checking on the pully recalls... I bought the Disco with all the dealer records and service records from the original owner. I guess i lucked out. But i'm gonna order the parts and try doing that myself. Worth saving the money by doing it yourself
hkp
Feb 21, 2011 08:39 AM
ColoDisco
Apr 9, 2010 11:25 AM
Robeye
Mar 11, 2008 12:16 PM
DeepBlueWater
Nov 11, 2007 01:21 PM
kfordric
Jun 19, 2005 01:52 AM
