What is the red plastic ring/grommet on the intake manifold vacuum line called
Old Sep 17, 2013 | 09:11 AM
ZGPhoto's Avatar
Is ****** really edited out? Wow.. why?
Old Sep 17, 2013 | 10:32 AM
jafir's Avatar
Originally Posted by bcolins
I'm heading to a junk yard today that has some D1s,....will the red grommet from a D1 work? If so, how is it released/removed?
I don't think D1 has this part; I don't think they have a plastic vacuum line to the booster.
Old Sep 17, 2013 | 10:33 AM
jafir's Avatar
Originally Posted by drowssap
you can replace it with a ****** brass fitting from any hardware store and a tap.
b a r b e d brass fitting
I think you are thinking of the other fitting that everyone breaks.
Old Dec 12, 2023 | 01:14 PM
Jpcoldwell1127's Avatar
Need to order one of the Red circular plastic grommets (for lack of a better term) that goes at the end of the (1/2" diameter?) vacuum line that plugs into the intake manifold near the oil fill neck. Can someone tell me what that is called, and best source for one?
Brian
Part # LR052965 Kit-Intake Plug (go to an OEM manufacturer site and plug in this part number). I paid 9.39 USD
Old Dec 13, 2023 | 01:31 AM
JUKE179r's Avatar
I replaced my brake vacuum connector with a Saab part number 55557389 connector for $12. It’s a direct replacement. I use a long extension and went through the intake manifold to push out the old connector.
Old Dec 13, 2023 | 10:47 AM
Externet's Avatar
As I did not find its name, replaced it with a named 'red silicone' 12 years ago and has never complained for the christening since. But I believe bubble gum can work there as well.
Charlie_V
Jan 18, 2014 09:53 AM
dirtlord
Aug 20, 2013 09:55 AM
izi6969
Freelander
Oct 23, 2012 10:16 AM
footie11
Jul 6, 2011 09:17 AM
Rover Curious
Feb 15, 2009 06:52 AM
