what size tire can I fit on the spare....
Old May 17, 2010 | 04:31 PM
instg8r's Avatar
Default what size tire can I fit on the spare....
So I really need to get tires for my disco....
I'm pretty set on 265/70/r16's and I just thought will my spare wheel/tire still fit on the back of my rover with these tires...
anybody know?
Thanks
Matt
Old May 17, 2010 | 04:33 PM
You can take the spare tire carrier off and turn it upside down to give you more room for a bigger tire.
Old May 17, 2010 | 04:38 PM
instg8r's Avatar
I guess that will change its location alittle?
upside down or inside out?
Old May 17, 2010 | 04:46 PM
It will raise the tire a couple of inches, so a bigger tire will fit but it will block more of your view out the rear window.
Old May 17, 2010 | 06:09 PM
lipadj46's Avatar
Some people have just used the top 2 lugs that will raise it up enough to fit a 32" tire. Or you can flip it but that will lose you a little support unless you redrill and support. Then there are the brackets for $100.
Old May 17, 2010 | 06:42 PM
Long Haul's Avatar
I have my 33x12.50 on the stock carrier i just flipped my wheel inside out. Thats if you have steel wheels,wont work with the alloy wheels
Old May 17, 2010 | 07:38 PM
discoxd's Avatar
i was running my larger spare on my stock carrier for a while, but you also have to consider weight.. larger tires weigh significantly more than stock and put quite a strain on your rear door hinges, thats why i moved my spare up to my roof rack
wrongway1
Oct 20, 2013 03:24 PM
Madlands
Dec 11, 2012 10:19 PM
ScreamingLife
Oct 9, 2012 05:56 PM
Frank4
Feb 24, 2011 04:57 PM
RoverLover21
Nov 18, 2009 08:28 PM
