What size tools for the drain/fill of autom. transmission?
Old Feb 22, 2009 | 06:02 PM
llPANCHOll's Avatar
My bad...
Your right the oil drain is the 1 1/16th
As far as tools go I have had good luck at Ace, I give them my DL and go out to the truck to see if it fits befkre I buy it.
Old Feb 22, 2009 | 06:16 PM
Start the truck and shift through ALL the gears holding each one for about 5 seconds on the way down to 1st and then again on the way back to park.
Leave the engine running, truck level, and remove the fill plug and check/top off the trans fluid.
Old Feb 22, 2009 | 08:24 PM
Disco Fuego's Avatar
OK, I think I figured part of it out. The hose from the pump must have blocked of the bottoom of the filler hole allowing more to go in before it started overflowing. Once the fluid started coming out, I pulled out the hose now allowing all the overage to come out at once.
To make sure I had the right level, I opened the filler hole (without the engine running) and let the "overage" drain; about 1.5 quarts came out. Once it was almsot done dripping, I started the truck back up and went through the gears slowly (not quite spike's 5 seconds though) a few times. I then crawled back under and started pumping. I was able to get about another quart in before it started to drip out again. Closed it up and voila! If I did my calculations right, there should be 4 quarts in it, exactly the same amount that came out initially. Time for a beer...
Old Feb 22, 2009 | 10:57 PM
roverguy7's Avatar
sounds like you got it close enough. the one thing that you need to concern yourself with in the future is the temperature of the oil. atf expands a good amount with heat, so if you let it get too hot when youre filling it, you wont get the right amount in.
jalodge
Apr 15, 2014 02:16 PM
Grumpo
Oct 22, 2012 12:22 PM
Disco Alan
Apr 21, 2009 06:22 PM
llPANCHOll
Feb 7, 2009 10:13 PM
gtagg
Apr 6, 2007 09:25 PM
