What are these hoses and why do they look like this? Are these vacuum hoses?
Old Nov 21, 2022 | 08:15 PM
99discoCaleb's Avatar
4wd High
Default What are these hoses and why do they look like this? Are these vacuum hoses?
Just replaced my pcv valve with the 4x4 mod along with Valve cover gasket and came across these hoses and I'm confused in where they go. Any help would be greatly appreciated!
Behind coil pack
Old Nov 21, 2022 | 08:32 PM
mln01's Avatar
For the gazillionth time on this forum, they are vent lines for the front diff and transfer case and are meant to be open and not connected to anything.
Old Nov 22, 2022 | 05:22 AM
4wd High
Sorry when searching this forum I found the answer. Ty.
Old Nov 22, 2022 | 06:30 AM
XRAD's Avatar
download the RAVE manual. It will be a great help to you!
Old Nov 22, 2022 | 01:30 PM
JohnZo's Avatar
Default Just Breath
Originally Posted by Brandon318
Definitely been more and more common the last few months. Sort of feels like a bunch of people bought Discos at the end of summer/beginning of fall.
Maybe a little explanation will help. Axles heat up and cool down, so they need to breath so pressure doesn't build up and cause oil leaks, and vacuum doesn't build up when we drive into the pond and water sucks in. The tube's ends are placed up high so we can ford mighty streams and still keep the water out.
Old Nov 22, 2022 | 01:52 PM
disco96sd's Avatar
The transfer case breather hose on my D1 slipped off the firewall and fell against the exhaust manifold - the breather hose is plastic and it was melted closed - pressure built up in the transfer case and blew the gear oil out though the seals subsequently causing the transfer case to self-destruct from a lack of lubrication as I was driving on the highway. Good times
Old Nov 23, 2022 | 03:01 PM
JohnZo's Avatar
Unhappy Bummer
Bummer. Sounds like a case of all the wrong stars aligning.
Old Nov 24, 2022 | 07:32 AM
disco96sd's Avatar
It was a very whiney transfer case so it was going one way or the other but not fun breaking down - luckily it wasn't far from home away from home
bcurtman
Oct 8, 2019 01:28 PM
slabrat
Apr 29, 2013 09:59 AM
alanroberts50
Aug 23, 2009 03:44 PM
Switzer
Aug 13, 2009 04:23 AM
