What are these wires behind the headlights?
Old May 17, 2017 | 03:06 PM
Jeff Blake's Avatar
Default What are these wires behind the headlights?
While cutting out the headlight bracket, I chopped the wires off with an angle grinder... well, the plugs had to be cut anyway, but I didn't want to cut there.
I knicked this bundle of 8 wires. It might be a sensor, but I can't think of a sensor that needs 8 wires. Is it just looped back onto itself? Either way, I need to repair the wires, I just want to know what they are. Driver side has it too.
Thanks.
Referring to the black plug thing in the left of this picture
Old May 17, 2017 | 06:00 PM
mollusc's Avatar
Start the truck, push all the buttons, follow the smoke...
Old May 18, 2017 | 12:03 AM
MrValingo's Avatar
I think all that's there are headlight, low beam fog, high beam fog, and horn wiring.
Old May 18, 2017 | 12:07 AM
Jeff Blake's Avatar
I can't make any sense of it yet. I'm afraid to cut it apart without knowing what's inside. All 8 wires are black. If it was a sensor (highly doubtful) then I'd think there would be colored wires. If its just a cap for ground wires, ok, maybe, but why?
Old May 18, 2017 | 12:10 AM
MrValingo's Avatar
On the passenger side there are a bunch of ground wires bolted to the back of the core support that go into the headlight area
Old May 19, 2017 | 10:17 PM
emncfi's Avatar
I am guessing those capped off ones are the wiring for the adjustable beam headlight that the Europe ones have?
Old May 20, 2017 | 11:06 AM
OffroadFrance's Avatar
Thanks.
Jeff, do a larger photo to identify where the wires are as it's hard to tell from the close up.
If they are all black it's reasonable to believe they are all bundled earth grounds but I'm just guessing.
Old May 20, 2017 | 11:09 AM
Jeff Blake's Avatar
Offroad, this is the headlight area, with headlight removed
Anyway... All good... I just repaired the wires and continued on my way.
Old May 20, 2017 | 11:11 AM
Jeff, good result, a real winner eh
Nunezjoel13
Jan 28, 2018 06:31 PM
luckyd77
Jan 17, 2012 07:30 PM
VikingDiesel
May 26, 2009 02:43 PM
jay040472
Oct 8, 2008 07:55 PM
Street Wolf
Sep 27, 2008 08:58 AM
