What would this leak be?
Old Jul 14, 2014 | 11:52 AM
CANAMDiscovery's Avatar
Default What would this leak be?
Lower ball joint has oil on it. I have a grinding noise when turning hard right on the driver side front which led me to start looking around. I have some new tires and would like to get the suspension tightened up before putting them on and getting it aligned.
Could the grease in the bearing be washed out by this oil leak causing my grinding? Hmmm. Nice to have some opinions before tearing it down.
Old Jul 14, 2014 | 11:59 AM
dusty1's Avatar
Axle seal leak?
Grinding could be hub
Old Jul 14, 2014 | 06:20 PM
jeffh's Avatar
cv, thats where I would look
Old Jul 14, 2014 | 07:57 PM
Thanks,
May take it in to get diagnosed for sure, then order the parts,, nice to know what I am talking about before putting her on someone else's lift.
Could a bad hub be causing some steering wheel shimmy while cruising, as well as when applying break pressure?
Old Jul 15, 2014 | 10:12 AM
dusty1's Avatar
yes.
or could have warped rotor, as well.
Old Jul 16, 2014 | 12:31 AM
jfall's Avatar
My 1997 had that in the rear wheel.
Turns out it was a wheel bearing.
When you turn, the wheel will scrape stuff cause the bearing is toast.
Haha, I have an unused wheel bearing sitting in my house as do I have most of the engine gaskets, exhaust gaskets and studs. Someone could get all this cheap.
ToddD
Mar 25, 2015 04:53 PM
dobe1canobe
Mar 28, 2014 06:53 AM
KlamathMatt
Feb 26, 2013 01:25 AM
bosshogt
Dec 23, 2011 10:24 AM
rgrizzard
Mar 6, 2008 10:16 AM
