What year was the upgraded SRD500070 SLABS introduced?
Old 04-27-2015, 08:46 AM
mln01's Avatar
Default What year was the upgraded SRD500070 SLABS introduced?
I know the upgraded SLABS (SRD500070) was used in the '04 Discovery when diff lock was reintroduced, but does anyone know whether or not the '03s had the SRD500070 too? There's an '03 being parted out locally and I'd like to know whether or not it has the "new" SLABS before I take the time to go try pulling it. Thanks.
Old 04-27-2015, 09:01 AM
abran's Avatar
Not sure if 03' came with the right ECU, but a knowledgable member on AULRO says there are 2 that work:
"Yes. The SRD000150 and SRD500070 at least will correctly respond to engaged CDL"
Also, you need to make sure that the SLS matches your rig(as in do you have active SLS, if so does the donor ECU or vice versa)
78KITCAR
10-12-2012 07:42 AM
jigray3
11-13-2007 04:27 PM
fgorli
10-23-2007 03:05 PM
huckleberry
12-03-2006 02:12 PM
abethlen
01-09-2006 09:12 PM
Quick Reply: What year was the upgraded SRD500070 SLABS introduced?
