Wheel Hubs
Old Jan 27, 2022 | 09:46 AM
Blamo35's Avatar
Default Wheel Hubs
my 04 has a couple of bad wheel bearings, front driver hub has a lot of play and rear passenger hub is missing a lug stud. I want to replace all the wheel hubs just for peace of mind. Any reccomendations? are aftermarket hub assemblies ok? or should i be sticking to OEM?
Old Jan 28, 2022 | 07:04 AM
Alex_M's Avatar
I've used a ton of cheapie eBay hub assemblies with good luck. Others have had mixed results, but out of half a dozen or more I've never had one fail.
Old Jan 28, 2022 | 02:52 PM
Harvlr's Avatar
Different vehicle but on a Dakota I used to have I foolishly used the “economy” hubs and needed to replace them again about 50,000km later.
There are exceptions but usually OEM quality is similar to genuine LR. Aftermarket is often, but not always, poorer quality.
Old Jan 28, 2022 | 05:39 PM
Brandon318's Avatar
The only hubs you should buy right now with the current supply out there is the Proline hub from Rovers North or OEM hubs. Do not buy hubs from Atlantic British right now. Do not buy any hubs from Lucky 8 right now. Whatever batch they have in their warehouse at the moment are hot garbage from China. I've had to replace NINE this year because of that. Finally found hubs made in the UK that are awesome from Rovers North.
Old Jan 31, 2022 | 11:59 AM
Harvlr's Avatar
Thanks for that info Brandon. That’s really good to know.
Old Jan 31, 2022 | 06:20 PM
Blamo35's Avatar
thanks everyone for the help
zuke
May 26, 2020 09:16 AM
dms6601
Oct 13, 2013 01:20 PM
Externet
Aug 26, 2013 06:45 PM
bmayer01
May 11, 2008 10:38 AM
