Where is cam sensor located on 2000 Disco?
Old Jun 23, 2008 | 07:29 AM
mtfife's Avatar
Default Where is cam sensor located on 2000 Disco?
Is cam sensor in front or back of head, and which side. Do I have to remove other components to get to it?
Thanks-
mtfife
Old Jun 23, 2008 | 08:10 AM
Default RE: Where is cam sensor located on 2000 Disco?
Why do you ask, do you have a fault code for it, what is your engine doing wrong, are you not getting any fuel?????????????????
Old Jun 23, 2008 | 08:45 AM
Landzu's Avatar
ORIGINAL: mtfife
Thanks-
mtfife
Its in front by the water pump.
You can see the wires next to the oil sending unit.
Old Jun 23, 2008 | 08:52 AM
mtfife's Avatar
Good morning Mike-
I am the same guy having probs with the P1884. I have replaced the crankshaft sensor and now looking into cam sensor. No codes for it, but at a loss. Again, the engine fires strong for several revs and immediately shuts off. I swear the computer is shutting it down based on some input from something. Fuel and spark are both there initially, but shut off after several revolutions. Tach registers during start, but goes off when it shuts down (almost immediately). Is there a computer reset?
Old Jun 23, 2008 | 08:59 AM
Before you jump into the replacement of the cam semsor, verify you are not getting any fuel and or use a good scanner and see what sort of signal the sensor is putting out.
cgeschwell
Feb 23, 2011 01:01 PM
booper169
Oct 22, 2010 07:31 AM
marlymarl
Feb 18, 2010 05:37 AM
sheelhorse
Jun 25, 2009 10:39 PM
jycsalas
Jun 10, 2009 04:37 PM
